Overheating
Discussion in '1st Gen Tundras (2000-2006)' started by Rmartinez, Oct 19, 2023.
  1. Oct 19, 2023 at 11:15 PM
    Rmartinez
    Rmartinez [OP] New Member
    02 tundra limited
    I have an 02 tundra that's overheating on idle. I replaced the radiator and thermostat. When I see that it's overheating I add coolant and temp will remain good for a while until it starts overheating again on idle. I don't see any visible leak of coolant. What could be the cause?
  2. Oct 19, 2023 at 11:43 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    If V8, see below...
    • Could be a leak at the by pass hose for the throttle body.
    • Could be a leak at the cross over pipe at the back of the engine.
    • Could be leaking from hoses from oil cooler.
    I see you have an access cab from profile pic. What engine? V8/V6? 2WD/4WD?
  3. Oct 19, 2023 at 11:50 PM
    Rmartinez
    02 tundra limited
    Ahhh I will have to check that out..
    It's a V8 2WD
  4. Oct 20, 2023 at 4:32 AM
    shifty` Animals and insects don't do drugs
    Sounds like you have air in the system and didn’t burp it properly. When you replaced the thermostat, did you properly clock the jingle valve between 11-1 o’clock? How did you refill the system, and was the heater ON in the process so coolant and air was flowing thru the heater core and associated hoses? Did you fill on level ground? Also, you used the correct fluid right? (Red or pink)
  5. Oct 20, 2023 at 5:57 AM
    Rmartinez
    02 tundra limited
    Yes I placed the jingle at the 12 o'clock position.
    Yes the heater was on full blast when I was refiling it.
    I believe it's pink fluid.
  6. Oct 20, 2023 at 6:22 AM
    Mr Badwrench
    Mr Badwrench New Member
    Since it is only when idling...Is your fan clutch free spooling? I think they should only spin 1/2 a turn at operating temp. Easy thing to check anyway.
    Rmartinez[OP] and KNABORES like this.
  7. Oct 20, 2023 at 9:23 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    That was my thought as well bad fan clutch. Is your AC working normally at idle?
    Rmartinez[OP], Aerindel and KNABORES like this.
  8. Oct 20, 2023 at 2:57 PM
    Aerindel
    Aerindel New Member
    Montana
    Second the fan clutch. It should be very stiff and hard to turn when hot.
    Rmartinez[OP] likes this.
