Overheating when stopped and engine running
Discussion in '1st Gen Tundras (2000-2006)' started by 06toyoxsp, May 3, 2017.
  1. May 3, 2017 at 5:50 PM
    06toyoxsp
    06toyoxsp [OP] New Member
    Jeff
    2006 Tundra XSP
    K&N panel air filter Pioneer head unit with pioneer 6.5" speakers
    My 06 tundra started over heating few days ago, the temp gauge only spikes when i stop for more than a minute or so. It seems to be pushing coolant back into the overflow tank which causes the fluid to bubble as well. Please help
  2. May 3, 2017 at 5:55 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Thermostat stuck?
  3. May 3, 2017 at 5:59 PM
    06toyoxsp
    Jeff
    2006 Tundra XSP
    Idk, i've considered that...i heard u can put it in a bucket of hot water to see if it opens up. So i think i might try that. What else you think it could be?
  4. May 3, 2017 at 6:31 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Most likely thermostat if it isn't a radiator or hose leak.
  5. May 3, 2017 at 7:34 PM
    Also clogged radiator??? I took my T100 same issue my thermostat was good but radiator was clogged took local radiator shop they took apart n cleaned it no issues
  6. May 3, 2017 at 7:41 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    I wouldn't suspect the thermostat, but it could be the fan clutch. If the thermostat won't open, it would happen at all speeds. A problem with the fan clutch will show up when stopped since that's when there's no air across the radiator. Check youtube for ways to check the fan clutch.
    landphil likes this.
  7. May 3, 2017 at 8:08 PM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Most likely cause-thermostat. They generally run about 15-30$$. Should be an easy swap. Have a bucket and extra rad fluid.
  8. May 3, 2017 at 8:14 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Most likely: fan clutch or low fluid level.
    Less likely: water pump or belt
    Least likely but possible: clog in radiator, debris in front of radiator, thermostat
    FlashCulprit likes this.
  9. May 3, 2017 at 8:14 PM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    I came here to say basically this. Haha
  10. May 3, 2017 at 8:23 PM
    JMB
    JMB I buy Nickelback albums at Target.
    Chesapeake, VA
    2013 Super White Tundra DC
    What he said. Not moving equals no air flow.
  11. May 4, 2017 at 1:24 PM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    This, if ya have a lot of miles, infrequent antifreeze changes and hard water they get clogged. The only way to repair them is get a new one or have it routed out or a new core put in.
