Overheating issues w towing
Discussion in 'General Tundra Discussion' started by Claystundy805, Jun 15, 2021.
  1. Jun 15, 2021 at 8:33 PM
    Claystundy805
    Claystundy805 [OP] Beachbum805
    Clay
    White 2016 Tundra TRD/Limited
    I took my 21 ft trailer out for the first trip of any distance last week. It towed like a champ, but I noticed going up and down the grade the temperature gauge showed it was getting hotter. I’m new to towing and basically mechanical illiterate, but wanted to know if there are mods I would need to get down the road for this. Wanna start taking the family on longer trips and was wondering what would be some upgrades that would be important for towing longer distances. Any advice much appreciated.
    Rica25 likes this.
  2. Jun 15, 2021 at 8:35 PM
    Rica25
    Ricardo
    Tulare
    What engine do you have?
  3. Jun 15, 2021 at 8:38 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    What do you consider getting hotter? Where was the needle, in the red?
    Rica25 likes this.
  4. Jun 15, 2021 at 9:54 PM
    Claystundy805
    Clay
    5.7 liter 8 cylinder
    The needle was was over the half way mark but not near the red, and returned to normal once on flatter road
    Rica25 likes this.
  5. Jun 15, 2021 at 9:57 PM
    TILLY
    Massachusetts
    I personally think that's totally normal, and you're fine.
  6. Jun 15, 2021 at 10:08 PM
    TunBrun
    TunBrun New Member
    Sunnyvale, CA
    2017 5.7L Crewmax Blazing Blue
    Use something to precisely monitor your temp. Trans temp is key. I use a Scan Gauge whenever I tow.
    Also using the S4 or S5 can keep temps lower. Something about the torque converter.
    jerryallday and Rica25 like this.
  7. Jun 15, 2021 at 10:17 PM
    Have you done a coolant service yet with a thermostat swap? Any weeping from the water pump?
    I’m assuming the coolant level is correct….
    Y0TA PR0 and Rica25 like this.
  8. Jun 15, 2021 at 10:55 PM
    Kanobi13
    Kanobi13 New Member
    Have you verified this with the scan gauge?
    Rica25 likes this.
  9. Jun 16, 2021 at 4:16 AM
    blanchard7684
    blanchard7684 New Member
    2016? What mileage?
    Not sure what actual temp you are hitting, what grade, what ambient temp...but all considered you might check your radiator cap. Possibly do coolant flush. The cooling system in the 5.7 Tundra is like the heart of the damn truck its insane.
    Rica25 likes this.
  10. Jun 16, 2021 at 4:59 AM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    OP did you expect the needle to stay near "C" the whole day? I wouldn't call this overheating unless you have steam billowing from under the hood.
    Rica25 likes this.
  11. Jun 16, 2021 at 5:12 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    I think you are fine. Depending on mileage I would take it to the shop and have them change fluids. Fresh fluids can make a big difference. Have them inspect for any leaks near the water pump like @ColoradoTJ stated. Common fail area. If they do the once over and say you are good; buy an OBD2 sensor and just monitor.
    Rica25 and ColoradoTJ like this.
  12. Jun 16, 2021 at 1:03 PM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Absolutely:thumbsup: Depending on speed,road conditions and load, preventing needless shifting by choosing a gear that keeps the TC locked will do wonders to keep the heat down. Problem is, the Sequential Shifter will actually have to be touched to do this and like hazard flashers, park brakes and owner's manuals, they're all available but seldom used!:lalala::D
    Rica25 likes this.
  13. Jun 16, 2021 at 1:20 PM
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    2014 Silver Tundra SR5
    3in ToYtech lift on Tundra and 2.5in in the rear. Tow Mirrors. Toyota grill, and Front bumber. New 6in antenna. Repainted the stepping boards
    I also pull a 22ft travel trailer and i have notice when we go up the hill and mountains in New Mexico the needle move. But it was never in the red or close to it. When we where in Midland it was in the middle and never move again only when going up hill I notice it move.
    Rica25 likes this.
  14. Jun 16, 2021 at 2:17 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Without you quantifying the temp change in any real way it is hard to know what you are getting?
    When you walk up an incline dont you get hotter too?
    I am serious,did you have any reason at all to worry about the temp gauge or have you not had one before to know that the entire point of one is to show the changes in temp as you drive around?
    In order to be of any real use to you we need to know what actually was happening,make sense?
    Were you Overheating as you suggest or just Heating which is normal?
    14burrito and Rica25 like this.
  15. Jun 16, 2021 at 2:27 PM
    Smallmouth King
    Smallmouth King New Member
    2021 Tundra Limited 4x4 Crewmax
    Bakflip MX4, Husky Liners X-ACT
    A little over half way on the gauge is not a problem, IMHO.
    Rica25 likes this.
  16. Jun 16, 2021 at 2:40 PM
    SSPey
    SSPey .
    Oregon
    2021 DinoSR5
    As others have noted, nothing unusual to see the gauge move a bit, but maybe a good idea to get fluids checked / replaced. Regarding mods, probably not, as your 2016 has a transmission cooler integrated with the AC condenser. However, do know that the “lifetime automatic transmission fluid” does require occasional replacement (drain and refill, not a flush) on an accelerated schedule when towing, listed as a “severe” use in the owner’s manual.
  17. Jun 16, 2021 at 4:05 PM
    The idiot gauges in vehicles really don’t show real time/actual temps.
    That is why I purchased the EDGE CTS3 Monitor.
    Kgfit85, Rica25 and Blue Thunder like this.
  18. Jun 16, 2021 at 4:12 PM
    Kanobi13
    Kanobi13 New Member
    Did you use the edge on your Tundra
    Rica25 and ColoradoTJ[QUOTED] like this.
  19. Jun 16, 2021 at 4:16 PM
    Blue Thunder
    Washington
    This.
  20. Jun 16, 2021 at 4:51 PM
    No. I should have.
    Not gonna lie, I put a smack down on that Tundra for 89k miles.
    Kanobi13[QUOTED] and Rica25 like this.
  21. Aug 20, 2021 at 11:11 AM
    Ders
    Ders Washington
    Washington
    2014 Tundra
    MKW Chrome Off-Road Wheels 275/65R20 Tires Bilstein 5100 Middle Setting In the Front, 1/2 Block in the Rear Highway Products Gull Wing with Roof Rack Tracks Protech lumber rack LED headlight and foglight bulbs 30% Front window tints Boost Auto Tow Mirrors
    Just to throw my 2cents in
    I wouldn't worry too much but just watch it.
    I tow a 6500lb travel trailer through the Cascades a few times a year, usually it’s no problem the temps stays right at half. But this last year we were going up a mountain pass and it was about 98deg outside and the temp started to rise, i shut off the AC and it fell back to normal.
    The second time this happened, we were trying to evacuate from a wild fire, similar conditions but it was going up a steep dirt road in 4x4 doing about 15miles per hour. Temp started to rise to about 3/4guage (i wasn't paying attention as the fire had my focus) anyways same deal shit off the AC and it returned to normal pretty fast. Either way we the proceeded home about 300miles and it was not an issue.
    that AC condenser coil as I understand is right by the radiator.
    I think they key is to watch it when going up hills and just make sure it doesn't get too hot, shutting the AC off seems to cool it down pretty fast.
    JLS in WA likes this.
  22. Aug 20, 2021 at 11:20 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Also make sure your cooling stack is clean/free from debris.
  23. Aug 20, 2021 at 11:53 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    And consider 4Lo if you're driving slow in 4x4, especially with a heavy trailer.
  24. Aug 20, 2021 at 1:00 PM
    Ders
    Ders Washington
    Washington
    2014 Tundra
    Yep, that crossed my mind but we were just trying to get the hell out of there, and you cant shift to 4lo in motion. Fire was a bit close for comfort
  25. Aug 23, 2021 at 7:00 PM
    drowhawk
    drowhawk New Member
    '19 Tundra SR5
    A little late to the party-
    Like others have said, we need the ECT PID from the PCM in order to make any sort of conclusion on how hot the engine was actually running.
    Ambient temperature would be helpful in addition to your gear selector position at the time and a/c on or off.
    There was ONE time with my 2010 when I was hauling my grossly overloaded toy hauler up a very long incline on a 102 degree day. I say it happened once because we don't get 102F days very often in upstate NY. Anyways, I had cruise set at 75mph, the dash was showing 118F ambient temp (from the sensor in the grill area), and I was screaming along at 4500rpm for about 8 minutes when eventually the coolant gauge moved. I didn't have a scanner setup at the time so I would say it moved about 3/4 of the way up with some healthy meat left before the red zone. I have no idea how hot it was but I remember noting I didn't hear the fan which with those temps it should have sounded like a jet engine. I turned the a/c off, slowed down to around 50, and shifted from drive to S3 and the needle dropped almost instantly. Oh and I had the heat cranking in the cab at this point to shed as much heat as I could.
    I have noticed on my 2019 that under these extreme load conditions, I hear the fan much more audibly, which leads me to believe my 2010 likely had a weak fan clutch. The gauge on my 2019 never moves but I also don't tow in D anymore as I get much better mileage in S5. After all, the cooling systems on these trucks can regulate the temperature of a small star so more than likely I was fine where the gauge was at. I never had any temperatures at the time so I was just cautious. If it happened now, I could see where the "danger zone" actually is.
  26. Dec 17, 2021 at 5:49 PM
    Ders
    Ders Washington
    Washington
    2014 Tundra
    What would be considered the danger zone for coolant temp? I got a scan gauge now to monitor trans and water temp more accurately?
  27. Aug 20, 2022 at 8:27 AM
    Ders
    Ders Washington
    Washington
    2014 Tundra
    Recently towed again and up some hills I saw the temp go to 216F, gauge was still middle of the dial. What would be too hot or considered non normal temp?
  28. Aug 20, 2022 at 8:45 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I don't think you have a transmission temperature gauge in your truck. That's the coolant you're looking at that's in the middle of the dial.
  29. Aug 20, 2022 at 8:49 AM
    Ders
    Ders Washington
    Washington
    2014 Tundra
    Sorry, that’s what I am talking about. The trans temps are very stable pan only get to about 210 or so, its been the coolant temp that seems to climb more when towing up hills, i have a scan tool that’s how I saw the 216F reading
  30. Aug 20, 2022 at 8:51 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    The coolant on my 19 reads around 204 while towing my 6,000 lb trailer. Have you checked the radiator fins for blockages from bugs etc? That can make it run hotter due to less airflow.
