Overheating at idle
Discussion in '1st Gen Tundras (2000-2006)' started by The tundy, Sep 10, 2018.
  1. Sep 10, 2018 at 5:19 PM
    The tundy
    The tundy [OP] New Member
    2001 tundra limited
    Hey guys I’m having a small issue with my 01 tundra with the 4.7 where at idle it starts running a little hot while sitting in traffic for a while. I have replaced the fan clutch, radiator, radiator cap, and thermostat all within the last 17k miles and it’s all been within the past couple months. Also when it does start running hot the ac stops blowing cold. As soon as I get going again the ac is freezing again and the truck runs like a top. This problem only occurs when I have the ac blowing it seems. I have some mechanical ability but this one really has me stumped. Thank you for any help.
  2. Sep 10, 2018 at 5:34 PM
    I would be looking at the water pump. Your not getting good circulation.
  3. Sep 10, 2018 at 5:35 PM
    TheBeast The Beach
    no leaks in any of the hoses ?
  4. Sep 10, 2018 at 5:42 PM
    The tundy
    2001 tundra limited
    If it was the water pump wouldn’t it be overheating all the time? The hoses are all firm while it’s running showing there is pressure.
  5. Sep 10, 2018 at 5:42 PM
    The tundy
    2001 tundra limited
    I have not noticed any leaks. coolant level seems to stay the same.
    TheBeast[QUOTED] likes this.
  6. Sep 10, 2018 at 6:36 PM
    TheBeast The Beach
    air bubble ? when was the last time you flushed it ?
  7. Sep 10, 2018 at 6:51 PM
    No, not necessarily. When your moving you have good airflow and additional RPM from the motor which propels the pump.
  8. Sep 10, 2018 at 6:54 PM
    The tundy
    2001 tundra limited
    Last time I replaced the radiator a little over 4 months ago
  9. Sep 10, 2018 at 6:55 PM
    The tundy
    2001 tundra limited
    Alright thanks for the tip I’m thinking that’s going to be next on my list whether it’s bad or not because I need to do the timing belt service too.
  10. Sep 10, 2018 at 7:05 PM
    Tag me when you reply. I’m really interested in the outcome. You have replaced everything but the pump.
    I have seen clutch fans bad out of the box...happened to me. Did you get a new one from Toyota or get a parts store replacement?
  11. Sep 10, 2018 at 7:13 PM
    The tundy
    2001 tundra limited
    I got it from autozone back in November I believe it was 17,000 miles ago I replaced it and it’s seemed to work fine. That is definitely something I will check though.
  12. Oct 27, 2018 at 9:14 PM
    JessiJane06Tundra
    JessiJane06Tundra New Member
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    Would like to know if the water pump did it for you. I'm in the exact same situation, I've handled it lately by throwing it in park and reving the engine lightly. My radiator seems great, no leaks, no coolant loss. Fan works. It won't heat up with the air conditioner on full blast as long as I'm driving, but within about 5 minutes of sitting still the temp starts creeping up, and the air conditioner isnt cold. In a cold rainy day with the defroster on I couldn't even get the temp to drop by cycling the engine, it wasn't even hot outside.
  13. Oct 28, 2018 at 12:07 AM
    ZPMAN
    Minnesota
    Maybe check your condenser to see if it's pluged, no air flow? 17 years of bugs?
  14. Oct 28, 2018 at 7:21 AM
    Professional Hand Model
    Hand Protectors
    How many miles you have?
  15. Oct 28, 2018 at 7:23 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Check your ac condenser. Maybe it’s plugged?
  16. Oct 28, 2018 at 8:41 AM
    JessiJane06Tundra
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    Will check that too thx
  17. Oct 28, 2018 at 8:45 AM
    JessiJane06Tundra
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    Pretty lowish around 135,00
  18. Oct 28, 2018 at 8:46 AM
    JessiJane06Tundra
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    I will check it out as well
    lsaami[QUOTED] likes this.
  19. Jul 31, 2019 at 9:18 AM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    Resurrecting an old thread -
    My wife's 2004 Sequoia 4.7 L will over heat in traffic on a hot day.
    I replaced the fan clutch earlier this year , new belt too.
    The dealer replaced the thermostat last year .
    Other than replacing the radiator , any other suggestions?
    I was thinking about bypassing the electric fan in the front of the radiator and just having it on a switch to run constantly.
  20. Jul 31, 2019 at 11:54 AM
    The tundy
    2001 tundra limited
    First I’d check if the radiator is holding pressure. While you have the engine running and it’s all warmed up try squeezing the radiator hoses. They should be firm. Also when was the last time you had the water pump done? From my experience the fan clutches have been extremely unreliable. I don’t know if it’s just me but I’ve gone through 3 of them in 40k miles. I just gave up with those things and I’m converting it to run electric fans.
  21. Jul 31, 2019 at 1:10 PM
    Mike Tread lightly.
    south carolina
    Warning with electric fans... If you do convert over to electric fans you need a manual bypass and a alarm at say 220 temp reading just in case the module fails to kick on and warps heads.
    ColoradoTJ likes this.
  22. Jul 31, 2019 at 1:11 PM
    15whtrd
    15whtrd Mr. Blonde
    I’m guessing water pump
  23. Jul 31, 2019 at 1:47 PM
    Porkchop Express
    Cody
    2017 Tundra CM
    Thanks for the replies.
    The truck has 230K miles , water pump was done for the 2nd time at 190K miles.
    15whtrd likes this.
  24. Jul 31, 2019 at 1:55 PM
    Porkchop Express
    Cody
    2017 Tundra CM
    The truck almost overheated when we were driving offroad to Silver City , I had to put it in 4LO and let the engine spin up to keep the fan moving air .
    Unfortunately , I cant do that in rush hour traffic at 90* .
    Im really thinking an electric conversion is the best option.
  25. Jul 31, 2019 at 2:15 PM
    15whtrd
    15whtrd Mr. Blonde
    Maybe you just got a bunk clutch fan. From what I’ve seen electric fans just don’t do the job that a clutch fan will. Switching to electric fans doesn’t solve your problem it’s only a Band-Aid unless the clutch fan was at fault to begin with.
  26. Jul 31, 2019 at 2:17 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Pressure from heat not from circulation. I feel you have a flow problem, take the cap off (when cold) to see if you see circulation of antifreeze after the tstat opens. At first antifreeze will overflow out the cap then drop and you will see it flowing. We had a Corolla’s impeller slipping on the shaft after the engine got hot. Hope this helps.
  27. Jul 31, 2019 at 2:29 PM
    Porkchop Express
    Cody
    2017 Tundra CM
    Ill try the cold start / circulation test tonight.
    I do have a new in box t-stat i could swap this weekend
  28. Aug 10, 2019 at 8:43 PM
    JessiJane06Tundra
    Jessica
    San Antonio
    06 Tundra crew cab
    Small lift
    When I was in a drive thru line not paying attention on a 100+ degree day it got hot enough to actually make it in the red zone which led me to the pinhole leak spewing steam from the radiator. No big surprise after replacing the radiator, hoses, and thermostat (because why not I'm already in there) it fixed my overheating issue. So to those asking what it could be, I would suggest a pressure test to start. Really should have been the first thing I did. Lucky for me no blown head gaskets or any other triggered issues (thanks to my Dad and youtube for teaching me how to replace a radiator when I was young)
  29. Aug 10, 2019 at 10:36 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Not over heating while driving due to air flowing. At idle no air thus it overheats. Its a good suggestion.
  30. Aug 10, 2019 at 10:49 PM
    koditten
    Kirk
    Midland of the Mitten
    Are you relying on the factory temperature gauge? They are wildly inaccurate.
    A Scan tool plugged into the OBDII port will give you a true water temperature.
    BTW, doesn't the Sequoia comes factory with an electric fan in addition to the belt driven fan?
