Overhead Switch Panel Options
Discussion in '2.5 Gen Tundras (2014-2021)' started by crafty762, Jan 9, 2020.
  1. Jan 9, 2020 at 4:22 PM
    crafty762
    crafty762 [OP] New Member
    Bill
    Minneapolis
    2017 Toyota Tundra SR5 TSS Offroad
    Neon floor lighting, LED bed lighting, Google mini, front LED light bar, custom USB power ports
    Anyone else trying to find a solution to installing a decent overhead switch panel into the sunglasses holder of a Gen 3 Tundra? From what I can tell, the SPOD panel is the only option for purchase but its price is an absolute crime (really... $520 for 6 blue buttons and a relay box?????). I'd love to see photos or hear about options that others have thought through. Thanks in advance for your help!
  2. Jan 9, 2020 at 9:50 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    I’ve got a switch pro and have it mounted down by the shifter. You could put it up above if you wanted.
  3. Jan 10, 2020 at 7:30 PM
    Elfine
    Elfine Doing my best to break this beast
    Pensacola, FL
    2017 Quicksand Tundra TRD
    Datin Metal Fab 18" Bed Rack, ARB Diff Breather, SDHQ ABS Guards, RCI Engine/Transmission/Fuel Skid, ICON Stage 5, Rago Bed Stiffener/Ditch light brackets, ARB twin air compressor, 295/70R18 Cooper Evolution M/T, Spydertrax 1.25" spacers
    This. Just saw yesterday where someone mounted it in that useless spot by the sunglasses holder. It's like a cardholder or something.
  4. Jan 11, 2020 at 11:52 AM
    airosey
    airosey 2009 CrewMax Limited 4x4
    East TN
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    Possibly mine. It takes a little work but the Switch-Pros SP-9100 control panel will fit in the useless card holder.
  5. Jan 11, 2020 at 12:14 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    A member on the 4runner forum, Tin I believe, 3d printed a switch panel where the sunglasses go...so perhaps a 3d print of some sort and it could look near factory...though I do not personally have that as an option, it couldn't be too tough...
  6. Jan 11, 2020 at 8:06 PM
    roadman
    roadman New Member
    2020 Limited CM
    Commenting for future reference. It would be awesome if someone developed a stock looking overhead switch panel with a reasonable price.
    AggiePhil and ZappBrannigan like this.
  7. Jan 11, 2020 at 8:41 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
  8. Jan 12, 2020 at 12:10 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
  9. Jan 12, 2020 at 12:17 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Are the overhead consoles longer in the Tundras without a sunroof?
  10. Jan 25, 2020 at 1:27 PM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    I have the Spod system... love it. i like the tactile switch over the button or touch screen of the switch pro. spod is also now offering a switch pro like system.
    the red, bulldog93, GWill and 5 others like this.
  11. Jan 25, 2020 at 11:39 PM
    gears_call
    gears_call New Member
    Orange County, CA
    2014 SR5
    King 2.5's l Method double standards l 35" BFG KO2 l SS Built front bumper/skid/valence l more to come....
    I’m going to have my switch pro installed at the end of the month. My idea is to trim the clip(?) paper holder, whatever you want to call it that sits behind the sunglass holder and mount it in its place. I’ll post pics here when it’s done.
    ZappBrannigan and fisherman951 like this.
  12. Jan 26, 2020 at 12:07 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  13. Jan 26, 2020 at 6:33 AM
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
  14. Jan 26, 2020 at 7:02 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    What do these switch panels do, do they simply provide the trigger for a relay to power your LED’s (or whatever)? I’m not grasping paying $600 for 6 switches, somebody please school me...
  15. Jan 26, 2020 at 7:39 AM
    gears_call
    Orange County, CA
    2014 SR5
    I know at least for the switch pro system you can do constant on, flash, strobe, burst strobe, dim lights, unit will act as a timer so after entered time of vehicle being off you can have it turn off items connected, one switch can be programmed as a master switch so it can turn on all switches or the desire number of items, also has a overdraw feature so it can work as a fuse and all these are run off a app.
    Jrharvey02[QUOTED] likes this.
  16. Jan 26, 2020 at 5:55 PM
    airosey
    East TN
    I’ve got the Switch-Pros and really like it. It’s a solid state unit with 8 relays built in. 4 are rated at 20 amps, the other 4 are 35 amps. You can configure a trigger, I have the reverse wire set as the trigger to turn on the rear bumper lights automatically. Each switch can be configured as constant or momentary, I use momentary for train horns for example. Each switch can also be set to power from battery or ACC, but using the app via Bluetooth overrides this. There’s a ton of features, this video is 13 minutes but worth watching. I had a lot of wiring and relays under the hood, the Switch-Pros allowed me to get rid of most of it.
    https://youtu.be/EEmIfdEmzAI
    kparrow, Pangaea, Wallygator and 2 others like this.
  17. Feb 1, 2020 at 12:29 PM
    gears_call
    Orange County, CA
    2014 SR5
    After some talk with the gentleman installing mine we both decided flush would be aesthetically pleasing. However it would be at the sacrifice of some practicality of seeing the switch. So.. he whipped up a little side mount and this was the final result. I ended up trimming the clip prematurely but I can’t see it being a overly expensive piece to replace. 81F2E8F2-4FD1-477F-993D-07ACEB040710.jpgBF9837E0-AC16-4E48-A784-BA1E99DEA48D.jpg
  18. Feb 1, 2020 at 12:37 PM
    sd_cavbluetundra
    sd_cavbluetundra New Member
    2019 Cavalry Blue Tundra TRD Sport
    -Backflip G2 cover -305-55-20 bfg k02
    I wonder if you can Somehow put it inside(with screws of course) the pop down glasses/storage thing! And close it whenever you don’t need it? and leaving it open whenever you’re in need of the lighting!
  19. Feb 1, 2020 at 12:40 PM
    gears_call
    Orange County, CA
    2014 SR5
    I’m sure you can. I saw there was a company with a bracket option for them for the Tacoma and 4 runner I believe? That was a option that was kicked around. My only concern was the unit “flopping” or swinging with the added weight when in the dirt.
  20. Feb 1, 2020 at 12:48 PM
    sd_cavbluetundra
    I would be concerned about it to.... now that I think about it. Well great location and set up!
  21. Feb 1, 2020 at 1:01 PM
    HulkSmurf14
    2014 Tundra Limited
    When you're hitting the trails, rocks or mud, wouldn't it be an ideal time to have it left down? Regardless, this would be an ideal OEM+ solution...
  22. Feb 1, 2020 at 1:05 PM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    I made a custom mount in the lame envelope spot. Love it right here and works great. It was pretty difficult to make the bracket though. Here’s a photo
  23. Feb 1, 2020 at 1:06 PM
    gears_call
    Orange County, CA
    2014 SR5
    Yes. But that’s where the issue lies. The sunglasses holder folds down in a pendulum type motion of travel. Now add the weight of the switch pro which with its added weight will only multiply the force of it swinging off road and that’s the concern I had
  24. Feb 1, 2020 at 1:07 PM
    gears_call
    Orange County, CA
    2014 SR5
    Nice! Looks good! Correct me if I’m wrong but is the surround Plastic?
  25. Feb 1, 2020 at 5:02 PM
    Bannock452
    Brandon
    Murrieta, CA
    Yea so around the Switch-Pros panel it’s a plastic cover. Below the black plastic I made 1/8” aluminum piece that holds the actual Switch-Pros.
    bulldog93 likes this.
  26. May 10, 2020 at 1:09 PM
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Are you selling these?
  27. May 10, 2020 at 1:11 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Trail command is dropping this tomorrow:
    Goes in that useless envelope slot like the one @Bannock452 made :thumbsup:
    vipgs3 and bulldog93 like this.
  28. May 10, 2020 at 1:29 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    I have had this for a long time. Interesting.....
  29. May 10, 2020 at 1:31 PM
    Damie Street
    Edsel
    South Carolina
    :spending: wonder if they could do a blank one? With no lights. Want to mount my HAM radio there.
    CallsignKodiak likes this.
  30. May 10, 2020 at 1:32 PM
    Damie Street
    Edsel
    South Carolina
    Did you make that or buy it?
