Overhead interior light
Discussion in 'Lighting' started by rons23, Sep 9, 2015.
  1. Sep 9, 2015 at 4:09 PM
    rons23
    rons23 [OP] Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    My interior light is not shutting off after delay. I hear it click, but light stays on. This is what I have trouble shooted so far. Pulled fuse-ok, inspected door switch, looks to be intact. I ran led strips under my headlights, they are tied to fuse box via fuse tap, also ran led strips in my engine bay straight to battery with inline fuse. I don't see them causing problems. Gotta be in the delay cut off switch, I don't know. All suggestions and opinions are greatly appreciated. Thanks
  2. Sep 9, 2015 at 4:29 PM
    Do u have to manually turn them on/off everytine?
  3. Sep 9, 2015 at 4:35 PM
    rons23
    Ron
    Kill Devil Hills
    Yes, won't come on when I open door, so I manually push switch on.
  4. Sep 9, 2015 at 8:54 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    What about the dash switch to the left of the steering wheel? Guessing that you want it in the "Door" position. When you mention that you checked the door switch, I assume you mean the one that the door presses when closed, on the door jamb.
  5. Sep 10, 2015 at 2:33 PM
    rons23
    Ron
    Kill Devil Hills
    Yes that switch, also had panel switch on door. Blew the fuse and I'm thinking there's a short. When it comes to electrical I'm amateur at best.
  6. Sep 11, 2015 at 10:21 AM
    Tiger Tundra
    Tiger Tundra New Member
    2015 Tundra TSS Off Road
    I can empathize when it comes to being electrically challenged. :annoyed:
    rons23[OP] likes this.
