Overdrive light not on dash truck is driving in overdrive
Discussion in '1st Gen Tundras (2000-2006)' started by Jollygreentoyota04, Nov 17, 2022.
  1. Nov 17, 2022 at 7:15 AM
    Jollygreentoyota04
    Jollygreentoyota04 [OP] New Member
    Ernest
    2004 Toyota tundra Limited extra cab
    Any help is much appreciated I have a 2004 tundra And I am dealing with no overdrive light on the dashboard I’ve already taken the steering wheel column off check the wire harness and everything is OK with that big problem driving down the road and overdrive seems to take a lot of gas any ideas on what this could be
  2. Nov 17, 2022 at 7:28 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Have you checked your trans fluid level?
    Mr.bee likes this.
  3. Nov 17, 2022 at 8:08 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Stock size tires?
  4. Nov 17, 2022 at 10:55 AM
    Jollygreentoyota04
    Ernest
    Yes I did check it and it looks fine and at the proper level
  5. Nov 17, 2022 at 10:57 AM
    Jollygreentoyota04
    Ernest
    So my check engine light just went on last night and then I did some troubleshooting and came across the pink milkshake dilemma and freaked out when I looked inside the reserve which was empty and had a small amount of pinkliquid. The vehicle did not get hot and the radiator level was to the top clean no leaks
  6. Nov 17, 2022 at 11:00 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    @ someone who knows better
    will wp bushings leak into the oil pan?
    @Jollygreentoyota04
    did you check the oil?
  7. Nov 17, 2022 at 11:27 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Ouch. I hope not. Sometimes it can be hard to detect pink milkshake just by looking at the transmission dipstick since both are red-ish in color.
    I would crack open your transmission pan drain plug and inspect it that way. A drain and fill never hurts. You'll need 4-5 quarts. If you truly have coolant in your transmission that's a whole new can of worms but we'll try to help.
    Is it the original radiator? Coming up on 19 years old.
  8. Nov 17, 2022 at 11:37 AM
    Jollygreentoyota04
    Ernest
    I bought this truck used about a year ago and looking at the radiator it definitely looks like it could be the original it’s a denso . Overdrive light does not come on and There is a pulling feel and So I started reading and the general opinion was that it could be the wire harness underneath the steering column.. wire harnesses was ok.Is there another harness relay or fuse connected to the overdrive thanks for all your opinion
  9. Nov 17, 2022 at 11:42 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @Festerw didn't you have that issue with the overdrive button?
  10. Nov 17, 2022 at 11:57 AM
    Jollygreentoyota04
    Ernest
    Yes .. overdrive button issue was my first concern when I jumped over to the radiator…So do I need to replace the gearshift ..
  11. Nov 17, 2022 at 1:14 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I was tagging another member that had a similar issue to get his thoughts. Let's see what he says.
  12. Nov 17, 2022 at 1:20 PM
    shifty` In South Dakota Trouble ain't hard to find
    Toyota uses red (/pink) coolant, so pink is normal. If the coolant is cloudy pink, like pepto bismol, that's a huge issue, and could potentially cause this. If it's the case, you need to stop driving it ASAP, replace the radiator with genuine Denso, full radiator flush, full trans flush, but passive flush, not forced flush.
  13. Nov 17, 2022 at 1:58 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I did. The harness under the wheel isn't the issue it's right at the end of the shifter. If memory serves you have to actually pull the shifter out to be able to see the damage.
    FirstGenVol[QUOTED] likes this.
  14. Nov 18, 2022 at 3:01 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    This is a little unclear to me. Let's start with the OD light. Are you saying that when you press the OD button (so that it's in the out position) on the shift lever that the OD Off light does not illuminate on the dash? Did you check the bulb?
    What happens under the following conditions: you're driving over 50 mph at light throttle on level ground, and you press the OD Off button. Does the RPM change?
    What do you mean by this?
