Over spray on glass
Discussion in 'Detailing' started by shhernandez74, Sep 18, 2018.
  1. Sep 18, 2018 at 10:09 PM
    shhernandez74
    shhernandez74 [OP] New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    whats up guys, I welded my iron fence this past weekend and then sprayed the welds down with some black spray paint. Later that day when I got in my truck I noticed that all my windows had over spray. I took a clay bar the next morning and clayed all the windows. I was able to remove most of it but there is still plenty left, is there any way I can polish my glass? I bought some water spot remover from chemical guys that I was told would work, anyone have any experience with it?
  2. Sep 18, 2018 at 10:44 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  3. Sep 19, 2018 at 2:58 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    Use some #0000 steel wool and glass cleaner for lube, it wont scratch the glass. If you pick up a piece of trash and damage the razor blade that will scratch the glass, and trust me you dont want to polish glass.........it sucks
    -Jason
    shhernandez74[OP] likes this.
  4. Sep 19, 2018 at 5:16 AM
    shhernandez74
    Samuel
    I will give this a try
  5. Sep 19, 2018 at 5:35 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
  6. Sep 19, 2018 at 5:53 AM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Super fine steel whole. Use compressed air to remove the fines or vacuum, NOT Water..( Rust will happen), then glass cleaner. I painted cars when I was a young man. Happened all the time when you work for a production shop. beat'em to fit paint'em to match... LOL
    4x4_Angel likes this.
  7. Sep 19, 2018 at 7:17 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    I would try a clay bar/medium-heavy before doing anything abrasive.
  8. Sep 19, 2018 at 7:20 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    this should do the job. or similar.. over the counter clay aren't as agressive.
    joonbug likes this.
  9. Sep 21, 2018 at 2:59 PM
    Merlin
    Merlin New Member
    Sunny South Florida
    All of the suggestions below have merit. Here are my thoughts...
    IF you do the razor blade method there are two process versions I would suggest.
    1) Metal Razor Blade 45 degree angle, spray with glass cleaner, pull and lift.
    Put at the starting point, spray, pull and lift. Going back and forth will scratch the glass.
    2) A plastic razor blade. A plastic razor blade will not/should not scratch glass.
    Again, position the blade at 45 degrees, spray, pull the blade, lift and repeat.
    I have used #0000 to clean chrome and as long as it is wet it seems fine.
    However, it does create micro-scratches. It is abrasive. Choose other methods if possible.
    Personally, I would use this as a more aggressive method. (if other methods do not work)
    I prefer the least aggressive method to get the job done.
    More aggressive clay may do the job if the overspray can be released from the surface.
    Aggressive clays are abrasive but it may work for you. It may not cause glass scratches.
    If it were me...Do you have a Dual Action (DA) Polishing machine?
    If so, I would try Rain‑X® X-treme Clean™ FIRST with a compound pad.
    I think of this as a compound for glass.
    I have had great results removing overspray with this and a DA using a correction pad.
    This product can be used by hand but your hands and arms may hate you. Remember...
    You cannot accomplish by hand what you can accomplish with a machine.
  10. Sep 21, 2018 at 3:26 PM
    Merlin
    Merlin New Member
    Sunny South Florida
    IMHO This is an advanced technique and should only be used by "experienced" detailers.
    For a novice, I would not suggest using a razor blade in a back and forth motion on glass or paint.
    If so, not only use the sandpaper but also bend the blade points away from the edges.
  11. Sep 21, 2018 at 3:36 PM
    ARES
    ARES ARES Fabrications
    God Bless America
    2018 Tundra TRD Cement
    You could try acetone for the windows. I use it alot and it removes paint easily just dont get it on anything you want to keep nice aka your vehicle paint. Apply some on a rag making sure its not dripping and wipe off the overspray from your windows.
  12. Sep 22, 2018 at 1:13 AM
    Inquiringone
    Ter
    NorCal 408
    If you use the razor blade in a wrong manner, or wrong angle, you can scratch the window...Just sayin....
  13. Sep 22, 2018 at 1:54 AM
    joesTundra
    joesTundra New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    good luck
  14. Sep 22, 2018 at 2:27 AM
    Twinky
    07 double cab work horse
    a mr clean eraser.
    a plastic scrapper honestly sounds like a good first option. with the magic eraser also.
  15. Sep 22, 2018 at 5:27 AM
    Wisconsin Tundra
    Wisconsin Tundra New Member
    Patrick
    Wisconsin
    2013 Tundra crewmax
    Lacquer thinner. Just be careful .
  16. Sep 22, 2018 at 6:16 PM
    shhernandez74
    Samuel
    I do have a DA polisher. I’m in Dallas and it’s been raining these past couple of days, as soon as it clears up I will go out there and give it a try. I will report back with my findings lol
