Outside mirror glass replacement
Discussion in '3rd Gen Tundras (2022+)' started by Tb2, Nov 9, 2023.
  1. Nov 9, 2023 at 3:42 AM
    Tb2
    Tb2 [OP] New Member
    James
    Has anyone replaced the glass in outside mirrors . My wife hit a mail box and shattered mirror glass , housing is fine . I have seen how to replace 2nd gen , but nothing on 3rd gen .
    When I put my cracked one back in it just pushed in with force .
    I am not sure if I did it correct or not . I have ordered a new glass and wanted to make sure I removed the old one correctly and placed the new one correctly as not to break something else
  2. Nov 9, 2023 at 5:41 AM
    Tb2
    Tb2 [OP] New Member
    James
    2022 1794 passenger side
  3. Nov 9, 2023 at 5:41 AM
    Tb2
    Tb2 [OP] New Member
    James
    I am not sure if you push up from bottom of glass or just pull straight off
  4. Nov 9, 2023 at 5:55 AM
    rhalama
    rhalama New Member
    2001 tundra 4.7 auto
    Any idea about a part # for my missing plastic piece that attaches to the glass? I bought a glass replacement but it did not come with the plastic piece that attaches to the glass---thanks in advance.Tundra mirror PXL_20231105_194034104.jpg
  5. Nov 20, 2023 at 6:45 AM
    Tb2
    Tb2 [OP] New Member
    James
    Has anybody removed the mirror from side mirrors ?
  6. Nov 20, 2023 at 6:51 AM
    99ways2die
    99ways2die New Member
    Yeah, why?
    Pic/step #9 in my unrelated thread:
    https://www.tundras.com/threads/how...-puddle-light-installation-and-wiring.122757/
    Removal/installation is similar to previous year models.
    When in doubt - YT it first (plus you have nothing to worry about since your mirror is already busted up, so you can't really break it any more when removing it). Obviously just be careful installing new glass, pushing in evenly and no cracking the new one. :)
  7. Nov 20, 2023 at 9:01 AM
    Tb2
    Tb2 [OP] New Member
    James
    The older generation u push up on bottom of mirror glass to remove the 3rd generation appears to be a straight push pull . I maybe wrong , that is why asked about anybody removing just the mirror glass .
    When it was hit the mirror glass was hanging by the wires . I just shoved it back in forcefull and it went in.
    I am not sure if that was correct way to remove it or to lift up from bottom .
    I was in a panic side of road putting back in so I didn’t spend a lot of time studying
  8. Nov 20, 2023 at 4:28 PM
    Tb2
    Tb2 [OP] New Member
    James
    Ok I just replace mirror glass purchase toyota dealer . you just pry glass straight out . Disconnect 2 wires and one connector which the hard part had to push black keeper down and pry connector out , helps to have extra set of hands . then just push new glass straight in with some force clips in .
    no pushing up from bottom needed different design from older models I guess . works perfect
    Leo's first likes this.
  9. Nov 20, 2023 at 4:46 PM
    meagain
    meagain New Member
    One piece of advice from me, don’t go to PartsGeek. I had to for mirror glass for my 17 Platinum, just one side, which meant an easy comparison to the other (original glass) side. The one I received from PG first had some sort of blemish that caused that prism/rainbow look in the glass, right in the middle. Very small, but noticeable enough and I’m weird in that I figure I should get new and unblemished goods when I buy brand new. Also, the BSM light on the PG one didn’t fully illuminate to look like a car, like my stock one. It still lights, I can see when another car comes up from it, but it’s lighter, not a full icon, and again, why not gimme good products?
    I emailed several times and received nothing. I figure the next step is a BBB complaint.
  10. Nov 20, 2023 at 5:27 PM
    Tb2
    Tb2 [OP] New Member
    James
    I bought mine from toyota dealer everything was perfect
    meagain likes this.
  11. Sep 3, 2024 at 6:19 PM
    Tammie
    Tammie New Member
    Tammie
    2019 tundra
    Na
  12. Sep 3, 2024 at 6:19 PM
    Tammie
    Tammie New Member
    Tammie
    2019 tundra
    Na
    Where did you buy the replacement glass
  13. Sep 3, 2024 at 7:34 PM
    Tb2
    Tb2 [OP] New Member
    James
    Dealer
    Tammie likes this.
  14. Sep 4, 2024 at 4:14 AM
    I have used Burco in the past. No issues at all.
    https://burcoinc.com/
