Outer tie rod stud bottoming out
Discussion in '1st Gen Tundras (2000-2006)' started by RRCC, May 22, 2025 at 7:07 AM.
  1. May 22, 2025 at 7:07 AM
    RRCC
    RRCC [OP] New Member
    Hi all.
    I am replacing the outer tie rod on my 2006 2wd Tundra. When I am trying to torque down the castle nut on the tie rod stud, the threads are bottoming out. I suspect that the tapered hole in the steering knuckle may be worn, but I am not sure. The original tie rod was replaced before I got the truck, so I have no way to compare the new part with the OEM part to see if the taper and thread length is the same. The old tie rod that I just pulled off was installed with a washer on it, so I suspect that they ran into the same problem and fixed it with a washer, but that seems like it would just lead to more problems.
    I am sure that the new tie rod is the correct part for the truck (NAPA p/n ATM SE3861R). Is there anything that can be done other than replacing the entire steering knuckle?
  2. May 22, 2025 at 10:26 AM
    The Black Mamba
    The Black Mamba Black Sneks Matter
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    First, welcome
    Second, pictures help a lot... I mean a lot.
    Third, unless someone on here has replaced theirs with the same Napa part (most are not) it will be difficult to say. I replaced mine with TRQ PSA55149
  3. May 22, 2025 at 12:31 PM
    shifty` All my rowdy friends have settled down
    What does it mean, "the threads are bottoming out on the nut"?
  4. May 22, 2025 at 12:34 PM
    pirates712
    pirates712 New Member
    2000 V8 AC 4x4
    I assume it means they're running out of threads on the tie rod where it comes through the knuckle - as if the threads aren't cut far enough or the diameter of the tapered portion is too small
    The Black Mamba and shifty` like this.
  5. May 22, 2025 at 7:55 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Use a thick washer to space the nut up. I see this every now and then with aftermarket tie rods.
  6. May 23, 2025 at 4:23 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Obviously, something is not right: either the tapered hole in the knuckle is too large or the tapered shaft on the tie rod end isn't made to OEM spec (it's either too long or too narrow).
    The knuckle doesn't wear out from use, time, or miles. So if the hole is too big it's because someone hogged out the hole to make an incorrect part fit. If that's the case, you need a new knuckle. The good news is that since this is not a part that wears out, you can get one used and it will perform as good as new. (They're all over eBay for $200 and under)
    If the shaft on the TRE is too long or narrow, you just need the correct part. It looks like you can get an OEM TRE for about $45 from any online Toyota dealer. Personally, that's what I'd do... and return the one from NAPA. If the OEM part doesn't fit properly, then you know you need to replace the knuckle.
    87warrior likes this.
  7. May 23, 2025 at 9:09 AM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    TRE's are usually replaced in pairs. What does the other side look like? If it has a washer too, then it's more likely the TRE being out of spec than the knuckle being the problem. If it does not have a washer. then it's more likely the knuckle.
