Ordered Bilstein 5100 shocks - did I make a mistake?
Discussion in 'Suspension' started by BrakeDust, Jan 29, 2021.
  1. Jan 29, 2021 at 6:53 AM
    BrakeDust
    BrakeDust [OP] New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    I have a bone stock 2021 SR5 Crewmax, came with factory 'black' shocks since it's not a TRD or Pro. Wanted to upgrade shocks since I'll be tearing apart the back end anyway since I'm adding Sumo springs and CB shackles.
    Ordered the 5100 shocks for front and rear. But then I saw this video:
    https://www.youtube.com/watch?v=5D1P6dF87D4
    The guys says that the yellow 4600 is internally identical to the 5100 except the 5100 is a little longer and has a softer feel due to larger diameter (ie. easier fluid flow.)
    My application:
    - City driving 95% of the timing
    - Camping about once a month, max out payload
    I'm planning on keeping the stock geometry, no lift. CB shackles are the +1 (ie. 0.65 lift)
    Should I have gone with 4600 instead?
  2. Jan 29, 2021 at 6:56 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    5100's albeit modestly, are an improvement over stock so i wouldn't say anything is wrong with what you did.
  3. Jan 29, 2021 at 7:05 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Either will be an improvement over the stock black shocks. The 5100s will allow you to adjust and lift the front if you ever want to. And I believe, installing the 5100s, even at the lowest setting is going to lift the truck about an inch. 5100s will ride firmer the higher they are set and have 3 adjustment settings.
    I have they yellow 4600s, part of the TRD OR package. They are better than the toyota black shocks but can't say they are anything special. One thing however, 4600s often show up for sale here or other places and can usually be purchased really cheap when people upgrade to a new lifted suspension. So, 4600s are likely the cheaper option. May not be cheaper for you since you already purchased 5100s.
    WFD473 likes this.
  4. Jan 29, 2021 at 7:11 AM
    TundraLLama
    TundraLLama New Member
    Massachusetts
    2015 Black Platinum Tundra
    Color matched mirror caps and door handles TRD dual exhaust TRD shift knob TRD Pro FOX shocks Spray in LINEX bed liner TRD 18” wheels FOX TRD Pro suspension Michelin 275/65r18 LTX AT2 Soft top Roll up bed cover Go Rhino RB10 running boards TRD Pro LED blackout headlights TRD Pro LED blackout fog lights TRD Pro grille AJT DESIGN blackout vent/shift/cup holder Wireless charging tray Remote starter Upgraded alpine speakers, amp, dual sub box. Rear underseat storage.
    I put 5100s on my platinum on the middle setting and raised the front end. The ride is firm but a little too harsh on the bumps for my liking. I did it primarily to get the lift in the front. If that is not what you’re after I guess it’s a slight improvement over the stock black shocks. I myself ordered the TRD pro suspension and I’m waiting for it to arrive. I want the best of both worlds some lift and a great ride
    GELCW and WFD473 like this.
  5. Jan 29, 2021 at 7:15 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    You will be fine with the 5100’s. The 4600’s are excellent shocks but I will say they are geared a LITTLE more towards people who use their trucks as trucks and not grocery getters. The are awesome with bed weight and during towing. With AT tires they can be a bit much with potholes.
    Unfortunately there is a main stream misconception that 4600’s come spec’d on the TRD Offroad package. Toyota OEM Bilstein shocks have much different valving and in many models are a smaller diameter (Meaning vehicle models). The 4600’s and 5100’s have a much stiffer ride than factory as per Bilstein. While the stock factory Bilstein’s are geared for comfort.
    xJuice likes this.
  6. Jan 29, 2021 at 7:20 AM
    BrakeDust
    Hill Country, TX
    Are you saying I got Bilsteins even with the non-TRD truck? (I don't think so)
    And you also say the 4600 is a good shock for towing - is the same true of 5100?
  7. Jan 29, 2021 at 7:26 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    No I believe the Bilstein shocks only came on the TRD Offroad packages...or at least that was the way the Tacoma’s came. I towed with both 4600’s and 5100’s. I honestly couldn’t tell much of a difference if at all. But it was a night and day difference coming from Toyota factory installed Bilstein’s.
    Truthfully after having Eibach shocks on my 5th gen 4Runner, I don’t know if I will ever buy Bilsteins again. IMHO Eibach nailed the balance between comfort and firmness...notice I didn’t say stiffer. Their valving is spot on and I will only use my Tundra to half capacity so I don’t need HD shocks which is what the 4600’s are marketed as.
    Sorry to confuse you OP, just wanted to be honest.
    Torque, 08TXTundra and toyofan87 like this.
  8. Jan 29, 2021 at 7:28 AM
    BrakeDust
    Hill Country, TX
    So I believe you're saying this:
    - No idea how the non-TRD black shocks behave (this is what I have)
    - TRD 'stock' Bilsteins are "meh"
    - Either the 4600 or 5100 are an upgrade from the TRD shocks
  9. Jan 29, 2021 at 7:41 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    Yes, no idea about the non-TRD shocks
    I am fine with stock Bilsteins because ANY aftermarket shock stiffens the ride and in NYC that ain’t fun.
    Yes, either will be an upgrade but with a decrease in comfort.
    Hoff likes this.
  10. Jan 29, 2021 at 8:16 AM
    BrakeDust
    Hill Country, TX
    Someone asks in the comments section of the video:
    The video guy replies:
    So I guess I'm GTG...
  11. Jan 29, 2021 at 8:32 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
  12. Jan 29, 2021 at 8:40 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    I am sorry but they are not the same shock... I spoke with Bilstein years back and the gentleman made it very clear that the valving was different. The factory OME are valved in some part according to the vehicle manufacturers specs. He also advised me that the 4600’s are a better shock for me because I towed and carried an ATV in the bed.
    There is a noticeable ride quality difference.
  13. Jan 29, 2021 at 8:45 AM
    BrakeDust
    Hill Country, TX
    So what's best for 95% daily city driving and 5% towing, with no off-roading?
    - Stock 'black' non-TRD shocks
    - Bilstein 4600
    - Bilstein 5100 (set to 0" lift, or stock height)
    What are you running? And what is the "noticeable ride quality difference" you experience? (Better, worse, softer, harder...)
  14. Jan 29, 2021 at 9:00 AM
    PlatinumPro
    again, 5100's are better in every way than the black shocks.
    shackles are going to work against your goal of improving ride quality if you plan on carrying a load in the bed (atv) or adding tongue weight (camper)
  15. Jan 29, 2021 at 9:00 AM
    AZBoatHauler
    So.Arizona
    Since you’re raising the rear I would definitely go with the 5100 (or upgrade to 6112). These trucks come with plenty of rake from the factory and I don’t think you’d want to increase it by raising the rear and leaving the front stock height.
    What made you buy the CB shackle?
    FWIW, my truck came with the yellow TRD OR Bilsteins and the 6112s I put on give a significantly better ride over the rough stuff. Ride is firm but certainly not jarring...
  16. Jan 29, 2021 at 9:02 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Yes, even Bilstein says the HD 4600 is the best and smoothest riding shock they make for these trucks.
  17. Jan 29, 2021 at 9:02 AM
    AZBoatHauler
    So.Arizona
    How would a CB shackle negatively impact ride quality? First I’ve heard that... my CB+2 certainly has not had a negative impact when I tow/haul.
  18. Jan 29, 2021 at 9:04 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    Sorry I should have clarified, I was responding to Tundyfundy post. Additionally I am running stock suspension on my 2020 Tundra. I am speaking of shocks and experiences from the different Toyota’s I have had over the years.
    The bottom line is that suspension “upgrades” is simply of a game of give and take.
    I personally prefer softer rides which many people don’t. I don’t Offroad but I do tow about 3 to 5k ATV trailers for long distances. I bought more truck than I need to make towing as safe and as comfortable as possible. The Tacoma and 4Runners I had handled it but did require a stiffer suspension.
    The Bilsteins in general will make cornering, higher speed driving, and off-roading much better than any of the factory shocks. But being that aftermarket shock are firmer in general...your are definitely going to feel more through the steering wheel. Smaller bumps are amplified especially with LT tires hence the give and take.
    The Bilsteins are excellent shocks but it’s going to feel more responsive and not as plush.
    Honestly OP, you should give Bilstein a call. I bought the 4600’s before I had any lifts and they we topping out with a lift so I had to go to 5100’s.
  19. Jan 29, 2021 at 9:12 AM
    BrakeDust
    Hill Country, TX
    Why are they working against it? It's only a good half-inch "lift." Stock rake is about 2", so I'll be at 2.5"
    I'm expecting that the shackles will reduce slop in the back end since they're much more rigid than the stock.
    I don't consider the +1 CB shackle a lift. Do I really need to compensate for a half inch 'lift' in the rear? My trailer will press down the back and I'll need to level things out with my WDH anyway.
    I picked CB since that's what I had before and I was happy with them. My goal is to keep the stock geometry if possible while adding some lateral stiffness.
    Crap. Return the 5100s and get 4600 instead? On the fence.
    Yes, never heard anyone complains that shackles made the ride worse. Quite the opposite. Indeed the shackles were part of the recipe to get rid of the dreaded "Bed Bounce" in my 2008.
    I don't have LT tires yet, just the stock Goodyear Duratracs. Eventually I'll get a stronger tire once these wear out.
  20. Jan 29, 2021 at 9:24 AM
    PlatinumPro
    i think my mind took a little friday break. what i meant is taller shackles paired with a load often result in the back end dipping more. probably won't affect ride so much but its a reason why a lot of guys that tow regularly also add bags to the rear.
  21. Jan 29, 2021 at 10:17 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Why not get the Eibach?
    Oey12 likes this.
  22. Jan 29, 2021 at 11:16 AM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    My old tundra came with the TRD off road Bilstein blue and yellow shocks. I swap them with 5100. The ride was a bit firmer but in a good way. It felt more controlled and less floaty. On my Tundra I have now came with the stock black shocks. I upgraded to the bilstein 6112 and happy with them also. In my opinion they ride better than 5100. But I wouldn't hesitate to get either one again. In fact I have the Bilstein 5100 on my Sequoia, I'm happy with both.
    Fwiw... you mentioned that you don't want any lift. But keep in mind the Bilstein 5100 will lift, even at the lowest setting it's aprox .75" lift.
    AZBoatHauler likes this.
  23. Jan 29, 2021 at 11:27 AM
    BrakeDust
    Hill Country, TX
    0.75" lift is not a big deal. The first time I tow a full load everything will get beat up and broken in pretty good, expect that 0.75 to get flattened out LOL
    But thanks for the 5100 review, I guess I'll hang on to them (my last truck had 4600 all around.)
  24. Jan 29, 2021 at 11:42 AM
    jalam321
    jalam321 New Member
    Yes you're right, it's not much lift. Might not even be that noticable. With the 5100 at lowest .75" setting in front and the CB+1 rear shackle, it should keep close to the factory rake.
  25. Jan 29, 2021 at 11:53 AM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    Interesting topic.
    When my 2015 rear shock (black) sprang a leak. I replaced both of the rears with a TRD blue/yellow shocks I purchased on here from a JTaco. I could tell the difference in the ride with the replacements. I am interested in leveling the truck eventually, but I would like a few payments under the rubber. So, I am following this thread.
    Of course, take that for what it is worth.
    Oey12 likes this.
  26. Jan 29, 2021 at 1:17 PM
    BrakeDust
    Hill Country, TX
    Ok found another review of the 5100 series, based on a 4Runner but it's a close cousin of the Tundra.
    What I like:
    - More roll/dive resistance than the stock black shocks
    - Can be left at stock height if desired.
    - Shock travel increased over stock
    - Negligible price difference vs 4600 (less than $100/corner, shipped)
    https://www.youtube.com/watch?v=kjc1ZcE0YpA
  27. Jan 30, 2021 at 3:28 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    I’m here because I plan to put 5100s on my ‘15 Tundra next week. No 6112s available.
    CB +3 Shackles on my ‘17 Pro Tundra and they have only improved ride, handling, and towing my 9k boat.
  28. Jan 30, 2021 at 8:14 AM
    AZBoatHauler
    So.Arizona
    Post up some more pics of the boat here! We are planning to kick off our 2021 boating season in 4 weeks!! Can’t wait!
    https://www.tundras.com/threads/post-up-those-water-toys-your-gas-piggie-hauls.63973/
    14burrito likes this.
  29. Jan 30, 2021 at 11:31 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I just did an upgrade from the 4600 TRD Offroad front shocks to the 5100’s on the middle setting.
    I need to note- I did this when it was time to purchase new tires, so in the same day I switched from stock 4600’s and 32” factory tires to now, 5100’s and 33” Cooper XLT’s
    ...gratuitous truck pictures (before/after)
    I do a TON of highway/freeway/city. I do drive into rock quarries and in farmland (wet, soft, uneven) at times.
    Switching from the 4600 to 5100 just last week, I observe that the 5100’s better absorb bumps and potholes with far less jarring than the 4600’s. The body seems to roll less when cornering and taking turns.
    I am really enjoying the leveled stance. I measured that the truck is now 3.5” taller in the front wheelwells. I can still climb aboard without a grab handle or a step.
    I see the 5100’s as an improvement from the 4600’s, and it sounds like my driving environment is similar to yours. Hope it helps!
    WVI likes this.
  30. Feb 1, 2021 at 12:36 AM
    BrakeDust
    Hill Country, TX
    Thanks everyone!
    Didn't install my 5100 shocks yet (still waiting for the tools to allow installation of my CB shackles at the same time.) I guess I'm looking at 0.8" lift to the front with the 5100 at the lowest setting, and 0.6" lift to the rear with the +1 CB shackle. Truck should maintain factory rake which is what I'm aiming for.
    Some more objective information from a shock vendor:
    https://www.shockwarehouse.com/news/bilstein-5100-vs-bilstein-heavy-duty.cfm
    "Although they are different brands and may appear to be very different from each other the Bilstein 5100 and Heavy Duty actually share many of the same components and ride characteristics.
    The main difference between the Bilstein Heavy Duty vs Bilstein 5100s is that the Heavy Duty or 4600 series is designed for stock height trucks and the 5100 Series is built for lifted trucks. The other major difference between the Heavy Duty and 5100 is that the Bilstein 5100 Series shocks have a zinc coating with a brushed metal shock body and a black boot while the Heavy Duty uses a painted yellow body with a blue dust boot.
    The Similarities: The 5100 series and the Heavy Duty shocks use the same technology internally. Both use the same internal valving and at stock height will ride the same (shocks for lifted trucks may use different valving settings in order to accommodate the extra weight of larger tires). Both shocks are pressurized with 360 psi of nitrogen to prevent shock fade and foaming of the shock oil. The outer construction of both shocks is identical as well with an extruded metal body rather for maximum strength and top of the line seals. The 5100 series and Heavy Duty 4600 series are both covered under Bilstein's limited lifetime warranty that protects against any manufacturer defects for the life of the shock.
    For stock height trucks, the Bilstein Heavy Duty yellow and blue shocks are the most popular choice, because they typically cost a few dollars less than the 5100 shocks and provide excellent performance for towing, light offroading or normal driving. Many customers do prefer the 5100 Series even on stock trucks because the shortest 5100s are typically built for 0 to 2 inches of suspension lift, meaning they can run the 5100 on their stock height truck but leave the option open for a lift later on down the road."
