Orange light under rear view mirror
Discussion in 'General Tundra Discussion' started by TXRailRoadBandit73, Jan 10, 2017.
  1. Jan 10, 2017 at 4:59 PM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    I briefly had a 2nd gen '13 CM that had a orange/amber light jnder rear view mirror that shined down on shifter...Do 3rd gens have this??? Now I have a '14 CM same trim as '13 but no light
  2. Jan 10, 2017 at 6:36 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I don't think i have a light on my 15 platinum
  3. Jan 10, 2017 at 6:44 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    I have always wondered what the hell it was? :notsure:
    DalTee likes this.
  4. Jan 10, 2017 at 7:00 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Same trim packages vary equipment-wise, from truck to truck, even within the same model year. Toyota is unpredictable that way. Are you sure that you have the same mirror? When I was searching for one to upgrade the one in my truck, I found that there were many different model numbers. Some had the light you're talking about with and without the compass, and/or the monitor for the back up camera. Some had a red compass, others blue/green. Pretty confusing.
  5. Jan 10, 2017 at 7:08 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    I have that light... it scared me to death coming home from a wedding one night this summer. What is that for?
  6. Jan 10, 2017 at 7:51 PM
    Assuming just to shine down shifter area
  7. Jan 10, 2017 at 7:57 PM
    The '13 I had I bought it used it still had window sticker inside manual all it said it was a SR5...The '14 I have now is a SR5 TSS the back up is on the radio head unit the '13 back up monitor was on the mirror with orange light
  8. Jan 11, 2017 at 4:03 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, my '11 SR5 mirror was just a mirror. No camera, no compass, no light. My neighbor's '07 SR5 has a compass and a light that shines on the shifter that is just below the lid on the center console. It's kind of a gamble.
  9. Jan 11, 2017 at 4:48 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    I work for the company that makes those mirrors.
    Internally it is called the PRNDL light because it effectively shines down on the shifter. The idea is that it provides a non-intrusive ambient lighting that will reduce your need for the map lamp.
    Toyota dropped the PRNDL feature with the 2014 refresh. This is not uncommon with vehicles that have the big radio screen as the radio now generates more than enough ambient light (typically too much).
  10. Jan 11, 2017 at 5:01 AM
    Virgils12
    Thanks for the explanation!
  11. Jan 15, 2017 at 10:39 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    I have a 13 with compass auto dim and homelink. Had wished there was light on the shifter cupholder area. Had a little fender bender and when I got it back from the body shop low and behold there's a little orange light on the bottom of the mirror. I can't find a switch anywhere. Weird, the truck only had 9k on it when I got it last Feb and was like new. It's 25k on it now.
  12. Jan 16, 2017 at 3:35 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    The light can be turned off with a software setting in the mirror. They probably pulled the battery for an extended period of time when the did bodywork. Long enough for your mirror to loose its mind.
    NewImprovedRon and Wynnded like this.
  13. Jan 16, 2017 at 3:24 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Interesting, your probably right. Why does everything have to be software controlled? What's wrong with giving us a simple switch to turn it on and off as we please? F-ers.
    NewImprovedRon likes this.
  14. Jan 16, 2017 at 3:40 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I have the orange light but doesn't do much good.
  15. Jan 16, 2017 at 3:40 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    F-ing engineers
  16. Jan 16, 2017 at 3:43 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Yeah, it helps a little. I'm still thinking about getting some leds to light up the cupholders.
