Option A or B?
Discussion in 'Wheels & Tires' started by LabRat, Sep 14, 2022.
  1. Sep 14, 2022 at 1:29 PM
    LabRat
    LabRat [OP] New Member
    Houston TX
    '14 Tunda
    So I've got two choices with the wheels on my Tundra. The 3rd (do nothing) isn't an option...
    They are the chrome ones that came with the "LA Edition" trim and are peeling. From a distance they're fine, but they look pretty bad up close.
    I can have them sandblasted and powder coated black for ~500-600 bucks, then I'd need a new set of the center caps. Anyone have a set or know where I can get a replacement set at a reasonable price?
    Option 2 would be to buy a set of dealer take offs and trade in the peely ones.
    At the end of the day the truck needs new tires anyways so I'm not opposed to either route.
  2. Sep 14, 2022 at 1:30 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Buy a set of take-offs would be my suggestion. I have done both.
  3. Sep 14, 2022 at 1:58 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Tundra wheels are usually not difficult to find, folks often sell them when upgrading. Not sure which year you have, but 2nd gen factory alloys can be found for not much coin as well as the Off Road package wheels. Should be able to find a nice set for 200-400 depending.
    Dealer take off could be great, depending on how much they are charging for the wheels. I would not spend the $ to refinish and powerdercoat what you have unless they are some special edition wheels, TSS or such, that you wanted to keep.
  4. Sep 15, 2022 at 6:22 AM
    LabRat
    Houston TX
    '14 Tunda
    Thanks for the input guys, the dealer take offs with a set of new (or barely use) tires will run ~2000-2500 for the style I'm looking at. They'll also take the current wheels as a trade in ($500-700) so that number drops again.
  5. Sep 15, 2022 at 6:26 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    Sounds like a deal to me to the take offs. Welcome to the forum! Post some pictures of your truck!
    LabRat[OP] likes this.
