Optima Battery Tie Down
Discussion in '2nd Gen Tundras (2007-2013)' started by Pistol0528, Dec 12, 2019.
  1. Dec 12, 2019 at 8:03 AM
    Pistol0528
    Pistol0528 [OP] New Member
    2013 Toyota Tundra CM
    How are you guys tying down your optima batteries?
    I recently installed a red top on my Tundra and found that the stock tie down was to tall to hold down the much smaller optima. I searched on this forum but was not able to find any ideas. Thanks for the help.
  2. Dec 12, 2019 at 9:53 AM
    SouthWestGA
    SouthWestGA New Member
    The last Optima I had came with a spacer tray from the factory as part of the packaging
    Maybe check to see if you tossed it?
    Pistol0528[OP] likes this.
  3. Dec 12, 2019 at 10:23 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    I had to use half of the spacer that came with mine (it came in 2 pieces) and it worked just fine. I did notice the factory battery tie down hooks are different lengths and I put them in backwards at first so maybe check that as well?
    Pistol0528[OP] and TheBeast like this.
