Opinion on the best drop-in liner
Discussion in '2.5 Gen Tundras (2014-2021)' started by drowhawk, Nov 11, 2020.
  1. Nov 11, 2020 at 5:36 AM
    drowhawk
    drowhawk [OP] New Member
    '19 Tundra SR5
    Before you respond: I NEED a plastic drop-in liner. It is the only setup that allows my snowmobile to roll smoothly into the bed. So no spray in or felt liners.
    I found a Pendaliner brand bed liner for $120 on carid. Toyota wants over $300 wholesale and from what I remember, the only thing special on my 2010 Tundra liner was that it had the Toyota logo on it.
    What are your thoughts on a decent drop-in bed liner?
  2. Nov 11, 2020 at 5:44 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    I would get the cheaper one.
    And take it out yearly to clean and protect the bed from rust somehow.
    drowhawk[OP] likes this.
  3. Nov 11, 2020 at 5:46 AM
    drowhawk
    '19 Tundra SR5
    I live in a road salt area so after ten years it's going to rust no matter what I do. Bed is covered when not hauling the sled though so it stays dry in the bed most of the time.
  4. Nov 11, 2020 at 6:01 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    If you are only going to use it in the winter months, then you should be fine as long as you clean your bed in the spring. Id go with the cheapest one and see how it holds up and if its junk then get the OEM one next year.
  5. Nov 11, 2020 at 6:11 AM
    bradleykd
    bradleykd New Member
    Brad
    Kentucky
    2016 Limited-BLACK
    I'd check facebook marketplace or craigslist. People are always pulling out perfectly good drop in liners to have spray in done. Once you pull one out, you have a hard time giving it away.
  6. Nov 11, 2020 at 6:12 AM
    CaptainGrumpus
    Maine
    Great point!!!!
    NewImprovedRon likes this.
  7. Nov 11, 2020 at 7:44 AM
    drowhawk
    '19 Tundra SR5
    Found plenty of used ones.... All of them 4+ hours away. For $120 I'll sit in my chair at home and save the 8hr drive
  8. Nov 11, 2020 at 7:49 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Around here everyone wants the used liners. We use them on trailers and ramps for the sled skis to slide on. You cut the bottom out and though away the sides.
    Personally I would still do a spray in. Just get the bottom of an old liner and place that in the bottom over top of your spray in to protect it from the carbides. Remove when done.
  9. Nov 11, 2020 at 8:10 AM
    drowhawk
    '19 Tundra SR5
    Just bought a house and this truck so spray in is just not in the fiscal realm of possibilities at the moment. I also had a 2010 with the plastic liner and no rust issues whatsoever as I kept the bed covered when not in use.
  10. Nov 11, 2020 at 9:49 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Understood. I've used drop in plastic liners on previous trucks without issue. I use to spray a thin coat of fluid film on the box to help with any slight rust that may form.
  11. Nov 11, 2020 at 2:44 PM
    drowhawk
    '19 Tundra SR5
    My 2010 would get a tiny layer of surface rust in spots where there was metal exposed and then wouldn't really grow much after that. I was impressed with the quality of steel. But fluid film or something similar before installing the liner would be a good precaution.
    Ruggybuggy likes this.
  12. Nov 11, 2020 at 9:04 PM
    rds95991
    rds95991 New Member
    2018 Super White Tundra CrewMax SR5 TRD
    Sound like you really need a truck bed mat. Those should be less than $100.00
  13. Jan 25, 2021 at 11:56 AM
    Roy Bert
    Roy Bert New Member
    Roy
    2018 Tundra Platinum
    @ drowhawk did you get one? Can you post a few pics?
  14. Jan 25, 2021 at 6:44 PM
    2mchfun
    Actually, bodyshops, and linex centers have them all of the time.
