Opinion on fixing tundra lean
Discussion in 'Suspension' started by captain_bij, Sep 26, 2018.
  1. Sep 26, 2018 at 7:41 PM
    captain_bij
    captain_bij [OP] New Member
    Bijan
    15’ Tundra Crewmax Platinum 4x4
    Wanted to get some feedback from you guys.
    Current setup:
    Kings front and rear - stock UCA
    I have about a 0.50” lean. Also about a 0.25” rake between passenger front and rear.
    Opinion #1:
    I think I want the front to sit 0.25” higher than rear, just in case my King’s settle more. (Really hate the way truck rake looks)
    Or
    Adjust it to be dead level.
    Opinion #2:
    Option 1) 0.50” coach builder shim left side and adjust the coils the remaining 0.25”/ leave it. Add one 0.50” shim right side or just adjust the coil 0.25” to be dead level.
    I know.. confusing post, but I think you guys get the idea.
  2. Sep 26, 2018 at 8:33 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Your kings are adjustable. You should be able to adjust your level w/o a shim by adjusting preload on you coils.
  3. Sep 27, 2018 at 5:14 AM
    captain_bij
    Bijan
    Yup, I know that. I’m asking if I should use shims along with preload for desired height or just use preload. I’m concerned about ride quality.
    Also asking if I should have front and rear at the exact leveled height or raise the front 0.25” higher than the rear.
    831Tun[QUOTED] likes this.
  4. Sep 27, 2018 at 6:09 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Don’t know why you’d intentionally raise the front higher than the rear, especially when you can adjust it to keep it perfectly level...:confused:
    Law323 and 15whtrd like this.
  5. Sep 27, 2018 at 6:31 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Why use shims when your coilovers are adjustable. It won’t affect ride whatsoever......we ARE talking about half an inch...(that’s what she said)
  6. Sep 27, 2018 at 7:36 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I think your numbers are so close that the adjustment won't have a noticeable effect on ride quality.
  7. Sep 27, 2018 at 7:45 AM
    captain_bij
    Bijan
    Great, thank you. That’s the answer I was looking for. Didn’t want to sacrifice ride quality for looks, that’s why I was contemplating shims.
