Opinion on aggresive tires/lift 2016 TRDpro
Discussion in 'Wheels & Tires' started by Poppapump456, Feb 16, 2018.
  1. Feb 16, 2018 at 2:47 PM
    Poppapump456
    Poppapump456 [OP] New Member
    2016 White TRD pro Tundra
    Nothing actual yet, only cosmetic.
    hey guys-
    New here. Purchased my TRDpro Tundra 2 years ago and I love this thing but as many of you may know the Michelin tires are a little lame looking. I started looking into new tires, which brought me into lifts, which put me into spacers, which threw me over to new rims. Things are getting expensive fast.
    I want a more aggressive looking tire, I also kind of like the offset look a little bit. Don’t like the tires completely flush. I’ve taken my truck to a couple local spots where they have given me quotes.
    The Nitto terra grapplers G2's look real nice. I’ve seen people fit them on the stock rims. This would save me a ton lol.
    I brought the truck into the Toyota dealership and they are certified to do everything under warranty. But they are suggesting a new set of rims, with a lift to achieve the Look I want. I don’t want to destroy the ride feeling of the TRD pro suspension. I know certain level kits and lifts can do this. But they claim to use ready lift and said everything will be done the correct way.
    Have I dug in too far? To those who have fit more aggressive tires on the stock rim, are you happy with the look? No rubbing? Can you share pics?
    I do like the negative offset look a lot. I don’t need it to be crazy thought. Maybe -24 or so. I’ll attach some pics of my truck as well as what I think kind of looks nice.
    I basically want to know if I can avoid lifting the truck and purchasing new rims just by fitting tires to the stock build. Will the beefier tire give me a slightly better stance without rubbing or looking ridiculous. I’m warning you up front I only know so much. I’m a newbie as far as truck modifications go.
    My truck is the white tundra. The silver is a look I really like. It doesn’t need to be that big of a lift or offset though. I’d be happy with a little less.
    Also any recommendation on wheels or tires let me know
    Black Wolf likes this.
  2. Feb 16, 2018 at 2:49 PM
    Welcome from
  3. Feb 16, 2018 at 3:01 PM
    ToyotaTundraMike
    2015 Tundra
    295/70/18's and a 1 1/2" spacer should do the trick. Maybe some shims/shackles from Coachbuilder for a little extra lift.
    Whatever you do, don't get those god awful rims that guy has on his silver truck.
    hi_rawb, 757TUNDRA, T500 and 2 others like this.
  4. Feb 16, 2018 at 3:06 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    If I had I PRO I don' think I'd change the suspension, that' what sets it apart otherwise buy a SR5. As far as wheels and tires there's plenty of options and plenty on this Forum with a PRO running aftermarket wheels and tires. Go through the build section and check some member's rides out to get some ideas.
    Marty McFly likes this.
  5. Feb 16, 2018 at 3:13 PM
    Rngr188
    Chad
    Harrison AR
  6. Feb 16, 2018 at 3:20 PM
    Welcome from CO.
  7. Feb 16, 2018 at 3:22 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Welcome!
  8. Feb 16, 2018 at 3:30 PM
    Poppapump456
    Y0TA PR0 likes this.
  9. Feb 16, 2018 at 3:41 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO.
  10. Feb 16, 2018 at 4:01 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Welcome from Ohio, nice rig :thumbsup:
  11. Feb 16, 2018 at 7:39 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Welcome from AZ
  12. Feb 17, 2018 at 5:08 AM
    Poppapump456
    That looks pretty nice… And you were able to achieve that just with coach builders? That would save me a ton of money and pretty much get me the look I want.
  13. Feb 17, 2018 at 5:51 AM
    Sutterhunter
    Sutterhunter New Member
    Placer County, CA
    2014 Black Platinum Tundra
    3/1 lift, 20" Fuel Trophy's
    Your truck looks great just the way it is. I would just roll with some beefier mud terrains and call it good.
  14. Feb 17, 2018 at 6:06 AM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    Welcome to the forum! I'd suggest when the time comes, replace your OEM wheels with something in the +20/+25 offset range with at least 295mm tires. If you aren't really planning on doing much off roading and want to stick with your OEM wheels, then get yourself some 1.25" wheel spacers.
    Poppapump456[OP] likes this.
  15. Feb 17, 2018 at 6:53 AM
    Cutter29
    Cutter29 ...
    Utah
    2015 Super White TRD PRO
    15 pro with 2 coachbuilder shims up front, +3 shackles in the back, 1.25” spidertrax spacers and 295/65 Goodyear duratrac. Last week I ditched the spacers for a +25 wheel and 295/70 ridge grapplers. +25 offset wheel sits pretty much the same as stock with spacer.
    MikeyMTBs, TRON, blue16 and 7 others like this.
  16. Feb 17, 2018 at 7:31 AM
    Poppapump456
    Yo our trucks look exactly the same I got the same black roof wrap LOL that’s awesome your truck w that stance in the first two pictures is exactly the look I want, how much did the total job run you?
  17. Feb 17, 2018 at 7:47 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome Dan. I agree with @Watt maker. CB shackles and shims, 295 70 18 and perhaps a 1.25 wheels spacer (Bora or Spidertrax) for an offset of +28. Then you'll find the truck with the larger tires feels a little sluggish. BD or Dap tune to make it peppy again...... It never ends.
    Watt maker likes this.
  18. Feb 17, 2018 at 7:50 AM
    [DELETED]
    [DELETED] New Member
    Jeff
    That looks great!:thumbsup:
  19. Feb 17, 2018 at 7:52 AM
    [DELETED]
    Jeff
    That ALSO looks great!!!
  20. Feb 17, 2018 at 1:33 PM
    Cutter29
    Cutter29 ...
    Utah
    I think the coach builder setup was $435 shipped (4x shims, +3 shackles, carrier bearing drop, and poly bushings)
    Spidertrax are $260 plus shipping. I’m actually about to list my old set in the for sale section.
    I did the shackles myself then paid to install shims and align it.
    cjmay13 likes this.
  21. Feb 17, 2018 at 6:54 PM
    [DELETED]
    Jeff
    Do you feel any difference in the articulation of the suspension after the CB Shims?
  22. Feb 17, 2018 at 7:05 PM
    [DELETED]
    Jeff
    WOW! The Pro's are LEGIT!
  23. Feb 17, 2018 at 9:39 PM
    Augparra
    Augparra New Member
    Domingo
    2014 Limited TRD crewmax
    Yea just like what everyone suggesting. CB shim you should be able to fit 295/70 no problem just need to remove the front tire air splitter. If you want you can save a little on shackles and get the toytec. If you want to lift the rear.
  24. Feb 18, 2018 at 12:51 PM
    Poppapump456
    Yeah see that’s what I’m trying to accomplish watt maker
  25. Feb 18, 2018 at 11:00 PM
    Augparra
    Augparra New Member
    Domingo
    Smart. I havnt check my spare tire spacing. Yea I need to look into a same size spare. Thanks @Watt maker for the reminder
  26. Feb 19, 2018 at 3:59 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Welcome from Michigan!
  27. Feb 19, 2018 at 4:10 AM
    drhntr
    drhntr New Member
    Derrick
    New Hampshire
    2017 Cement Pro DC
    GoRhino 2.0 Diamondback Switchback 295/70/18 TOYO AT3 TRD CAI Window Tint
    Welcome fom NH can’t wait to see what direction you go
  28. Feb 19, 2018 at 6:41 AM
    Poppapump456
    So from what I’ve read. The CB shackles and shims really won’t harm the TRD suspension. Which is partially the reason I purchased it. They will allow me to fit a meaner tire which is what I wanted. I am reading for the most part however that wheel spacers are bad.
  29. Feb 19, 2018 at 9:50 AM
    Augparra
    Augparra New Member
    Domingo
    I wouldn’t trust wheel spacer but that’s me. A co worker lost a wheel on the freeway due to a wheel spaced failing. Be safe and get new wheel.
  30. Sep 26, 2018 at 4:19 AM
    Airfire06
    Airfire06 New Member
    2016 trd pro
    Nothing yet
    Sometimes simple and clean is best...295/70r18 nitto G2s with Front flares removed that’s it
