oops
Discussion in '1st Gen Tundras (2000-2006)' started by wiggilez, May 14, 2023.
  1. May 14, 2023 at 1:49 PM
    wiggilez
    wiggilez [OP] New Member
    2004 access cab 4x4 tundra
    Topper, 1.2-2" lift, older motorola radio
    I was rebuilding a caliper cause the pistons were seized on one side, but then I accidentally broke the bleed valve off when I got it all back together.
    those with a keen eye might also notice that my tap isn't straight, and that would be because i drill my hole at an angle :/
  2. May 14, 2023 at 1:51 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    My first thought when I saw the picture was that you were going to say you broke the tap off.....
    BravoDeltaRomeo likes this.
  3. May 14, 2023 at 1:58 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 55k mi
    Hey the good news is now you get to do the 13WL upgrade
    bmf4069, N84434 and Sunnier like this.
  4. May 14, 2023 at 2:04 PM
    Sunnier
    Sunny
    San Diego, CA
    And now you can justify buying a home drill press.
    a lotta silver lining here, Buddy! :)
    bmf4069, landphil, N84434 and 3 others like this.
  5. May 14, 2023 at 2:13 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Sunnier[QUOTED] likes this.
  6. May 14, 2023 at 2:26 PM
    Aerindel
    Aerindel New Member
    Montana
    I had a tire chain break about a week after buying my tundra, which then wrapped around the axle, and tore the break line off with the fitting, and I ended up having to do this same repair to get that fitting out.
  7. May 14, 2023 at 8:15 PM
    wiggilez
    that tap not braking is about the only thing that went right this weekend.
    I've actually been looking at those little work bench mountable units as I don't really have enough space to justify a full size one.
