One rear leafs and poly bushings
Discussion in '2.5 Gen Tundras (2014-2021)' started by Nick1716, Dec 8, 2018.
  1. Dec 8, 2018 at 8:35 AM
    Nick1716
    Nick1716 [OP] New Member
    I want to try to instal my ome leaf springs and poly bushings today here is what came in the pack and I missing bushing sleeves?
  2. Dec 8, 2018 at 9:23 AM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    and looks like 2 extra bushing sets. Only need 2 sets per side.
  3. Dec 8, 2018 at 9:23 AM
    GiantsFanDan
    I would call OME or where you bought it form.
  4. Dec 8, 2018 at 9:25 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    The longer ones might replace the top bushings. No sleeves in those. Maybe one extra set of bushings per side?
  5. Dec 8, 2018 at 9:39 AM
    Nick1716
    The longer ones looks to be the top. I’m stumped if one end has a sleeve I’m supposed to reuse I think not as the stock leaf bushings are the same but I could be wrong..
    Mountun Goat likes this.
  6. Dec 8, 2018 at 9:45 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I remember scratching my head too with those. The long one is upper shackle. The short ones are front and rear leaf. Let me check my truck for sleeves
  7. Dec 8, 2018 at 9:49 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Never mind. I don’t have x-ray vision. Can’t see the bushing sleeves haha. That does seem odd. Like mentioned earlier call a OME install shop and ask. Im trying to remember but I think one of the leaf bolts is bigger than the other one. I think the front is no sleeve and the rear(more turning due to shackle) has the sleeve.
    15whtrd likes this.
  8. Dec 8, 2018 at 9:49 AM
    Nick1716
    So have you done these? Do I need more bushing sleeves?
    Mountun Goat[QUOTED] likes this.
  9. Dec 8, 2018 at 9:52 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    When I did mine it was just one of those wing it and see how it goes installs haha. I know I didn’t have to get more parts. And I know I was thinking wtf when I saw the bushing/sleeves before install
  10. Dec 8, 2018 at 9:55 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Nope I’m wrong. Front uses the sleeve because it’s not a greasable joint. Rear uses the greaseable bolts. See
  11. Dec 8, 2018 at 9:58 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Longer ones are for upper/frame bushing
    Shorter is for leaf pack.With sleeve.
    Mountun Goat and 831Tun like this.
  12. Dec 8, 2018 at 10:05 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Re use the upper oem sleeve for the new bushings*
  13. Dec 8, 2018 at 10:20 AM
    Nick1716
    Planned on that but looks like I’m gonna need another set of leaf bushing sleeves since I don’t have the greasable bolts and new shackles
  14. Dec 8, 2018 at 10:27 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Are you using ome packs?
  15. Dec 8, 2018 at 10:31 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Good luck getting the original sleeve out. I’m sure that will be seized in there
  16. Dec 8, 2018 at 10:50 AM
    Nick1716
    Yes
    dcsleeper408[QUOTED] likes this.
  17. Dec 8, 2018 at 11:09 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    You should be able to just use the lower bushings for now with oem shackle. Replace the uppers when you get the new shackles. Uppers are easy no need for a press.
  18. Dec 8, 2018 at 11:11 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Try sliding that lower sleeve over the oem shackle to see if the diameter fit. I believe they were same diameter.
  19. Dec 8, 2018 at 11:31 AM
    Nick1716
    Yes but my question is do I need 4 sleeves? With stock shackles? Front bushing sleeve, rear lower bushing sleeve on each side driver and passenger. yes I know I can reuse the upper shackle ones
  20. Dec 8, 2018 at 11:47 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    No, the ome leaf pack is already equipped with a bushing for front mount.
    You will just use the two in the rear with your shackles.
  21. Dec 8, 2018 at 3:31 PM
    Nick1716
    Ok for future reference for anyone you need another bushing sleeve (or leave it loose and sloppy without one what I did in the rear til Monday when I can machine one at work) if you use ome poly bushings. Also the bushing in the stock upper shackle doesn’t fit in the new poly upper bushings so I just left the stock upper bushings in. My guess is they do this to make you spend more money on the darn greasable shackles and pins
    landphil and Mountun Goat like this.
