ONE parking light not working after NSV lightbar install
Discussion in 'Lighting' started by SnowedIn, Mar 17, 2021.
  1. Mar 17, 2021 at 8:33 AM
    SnowedIn
    SnowedIn [OP] New Member
    Krista
    2018 Silver Tundra TRD TSS Package
    None...yet
    Last evening I installed the NSV hood bulge light bar. That thing is freaking awesome, but now my passenger side parking light isn't working. It works as a turn signal and flashes when I lock/unlock my truck. The driver's side is working fine. You guys have any ideas or suggestions on what I should check? Everything else is working fine, just that one dang parking light. Thanks.
  2. Mar 17, 2021 at 9:28 AM
    Easiest thing to start with is changing the bulb.
    excelw likes this.
  3. Mar 17, 2021 at 9:39 AM
    SnowedIn
    Krista
    None...yet
    Thanks, but the bulb works. It works for the turn signal and flashes when I lock or unlock the truck with the key fob.
  4. Mar 17, 2021 at 9:42 AM
    I had a similar issue on my 13. It worked as the signal and also flashed when it was locked or unlocked, but would not work as a DRL once the truck was running. It was the bulb in my case. :notsure:
  5. Mar 17, 2021 at 9:48 AM
    SnowedIn
    Krista
    None...yet
    LOL, guess I'll check the bulb. Is it a multi filament bulb or something? And do you know off the top of your head what the bulb size would be?
  6. Mar 17, 2021 at 10:07 AM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    I would probably start by pushing in on the back of all the pins in the connectors one more time. Maybe something isn't seated properly?
  7. Mar 17, 2021 at 10:42 AM
    SnowedIn
    Krista
    None...yet
    Thanks, I'll give that a shot too.
