One formula to rule them all
Discussion in 'Wheels & Tires' started by Samoan Thor, Oct 25, 2017.
  1. Oct 25, 2017 at 10:26 AM
    Samoan Thor
    Samoan Thor [OP] God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    What is the formula for psi on all different tire sizes? For example wheel size+tire size=34 psi? What is the correct formula? I wanted to see if anyone knows what it is so I don’t have to set a psi front and rear, test, add more or take out air, test, it’s too much work, I wanna get straight to the results with a proven formula, thanks.
  2. Oct 25, 2017 at 11:00 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I don't think its going to be that easy. It depends on the load rating of the tires, as well as the weight they are expected to carry, and to a lesser degree, your expected ride quality. The closest thing I've heard of to get it right is the Chalk Test.
  3. Oct 25, 2017 at 11:19 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Someone on here mentioned a chalk test that made a lot of sense. Wasn’t a formula though.
  4. Oct 25, 2017 at 11:24 AM
    Samoan Thor
    k, it was worth a shot, I thought it would be that easy but I guess chalk test it is, thanks
    yea chalk test will be the way, I was just wondering....
