one dim headlight bulb
Discussion in '2.5 Gen Tundras (2014-2021)' started by andnyleswillriot, Nov 30, 2024.
  1. Nov 30, 2024 at 6:45 AM
    andnyleswillriot
    andnyleswillriot [OP] Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    Hey all,
    So I installed some Auxito LED bulbs in my 2016 halogen headlights about 3 years ago. Recently the passenger side is quite a bit dimmer than the driver side. The hi beam is the same though. Guessing it's just time for new bulbs? Wanted to ask here before replacing since it's such a pain to get to the headlight bulb on our trucks. Thanks
  2. Nov 30, 2024 at 7:07 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    My advice would be to get the 2018+ OEM LED headlights with an @iHacker harness if you can afford it.
    I haven'r pulled the headlights since, although I did replace the halogen turn/DRL and parking lights with LEDs.
    Other advice is, surely you are removing the headlight and not going in from the fender well like the manual states.
    It only takes 10 minutes to pop the grille and headlights out..
    Good luck..
  3. Nov 30, 2024 at 8:05 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Ditto on the post above. Factory LED swap is amazing for the cost...well worth the coin.
  4. Dec 2, 2024 at 5:41 AM
    andnyleswillriot
    Breckenridge, CO
    Thanks but I have no money for a whole headlight upgrade over a bulb upgrade.
  5. Dec 2, 2024 at 6:41 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Swap bulb to good side.. if dimming follows, then it’s the bulb. If doesn’t, wiring..
