On with ignition power source near driver footwell
Discussion in '2.5 Gen Tundras (2014-2021)' started by TucsonTundra1794, Mar 11, 2021.
  1. Mar 11, 2021 at 9:19 AM
    TucsonTundra1794
    TucsonTundra1794 [OP] ASCM #6-11 I'll buy if you're willing to ship
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Hey guys I need to tap into power that comes on with ignition and I'd like it as close to driver footwell as possible. If needed I can run it to fusebox under hood and tie into one of the fuses. Thanks!
  2. Mar 11, 2021 at 9:26 AM
    AZBoatHauler
    So.Arizona
    The 12v outlet by the driver’s right knee comes to mind. Just pull down the HVAC controls and those panels pop out.
    As you stated, the footwell is right near the firewall pass through so you may just want to run an add-a-fuse or similar.
  3. Mar 11, 2021 at 9:39 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Yeah I was hoping to use the provided 6" lead off my device but I may just run an add a fuse back through the firewall. Thank you!
  4. Mar 11, 2021 at 9:47 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
  5. Mar 11, 2021 at 9:49 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
  6. Mar 11, 2021 at 10:15 AM
    glowblue
    VA
    :thumbsup::hattip:
  7. Mar 11, 2021 at 4:25 PM
    delphiwiz
    delphiwiz New Member
    Dave
    Butler, PA
    2019 Silver Tundra Ltd Dbl Cab
    Extang hard tri fold Tonneau-Tailgate step, Bed mat-Interior LED-LED Tail lights-LED Bed lights with tailgate open switch-Front and Back dash Cam-Short Antenna-Tailgate decal inserts-OEM Cargo bed divider-Tailgate lock-Remote starter-Console safe
    On my 2019 Ltd, there is a small fuse box behind the hood release cable, you will have to take out the side panel, pry the door sill and it will come out. There are fuse outlets not being utilized, one of them is powered on when keyed and another with constant 12V, I use it to power my Blackvue dash cam, you can buy a fuse extension tap and have a fused connection for additional protection.
    If you are lost, let us know and I will post a picture and point out the precise fuse locations with the Amazon part number, I'd do it now but sorry, my truck is parked at work.
  8. Mar 11, 2021 at 4:49 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Sweet! I'll look now and see if I have it. Thank you!
  9. Mar 14, 2021 at 3:19 PM
    CamTundra
    CamTundra New Member
    Camilo
    2008 Tundra SR5
    This all reads very well, but I will take you on your offer about the pictures or more info, I did find the electrical wiring on the link posted (which is great and awesome) but I have been trying to figured stuff out with littel success so far. I wonder how you did it. I am planning to add universal 12v at either side of the back seat to connect the tire air compressor that is 14 amps, since I would use it one at the time a 15 amp circuit would do it, hopefully I can mock what you did. https://www.amazon.com/gp/product/B071J3ZQBB/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8
  10. Mar 15, 2021 at 6:11 AM
    delphiwiz
    Dave
    Butler, PA
    Here is what I bought from Amazon
    Fuse Adapter
    https://www.amazon.com/dp/B01DYQM6EO/ref=cm_sw_r_cp_apa_fabc_FKGGG0AR7TFQQTZKTMG0?_encoding=UTF8
    Fuses
    https://www.amazon.com/dp/B07786GPGK/ref=cm_sw_r_cp_apa_fabc_6Y9Q3Y7ZCJVFN7CCGB9V?_encoding=UTF8
    When you pull the door sill bottom panel which is just clipped, the side cover which also has a plastic screw clip on bottom can be pulled out. There is a small plastic rectangular box on top with a cover, way back towards the firewall, it has the fuse layout marking on the top, remove the cover and you will see two rows of fuses.
    The right side towards the steering has the 4th slot free, this is the constant 12v, move up on the same row and the second blank slot after a few filled fuses is the Acc slot, which only turns on when the key is turned to Acc.
    Use the adapter from the first link from Amazon, it fits right in, use the fuse in the second slot of the Amazon adapter, you will need both fuses in to get power.
    Use the DMM to check continuity and volts and you should be set.
    I will try to get you a picture tonight.
    Dave
  11. Jun 15, 2021 at 11:00 AM
    VietGuy
    VietGuy New Member
    Houston
    2019 Tundra CrewMax Cement
    Hey Dave, were you able to take a picture of the fuse box? I’m alittle confused on how it looks like and a picture would help out a lot trying to wire up my dash cam. Thank you!
  12. Jun 15, 2021 at 2:45 PM
    2mchfun
    It's a very narrow box about 1 1/2" wide and maybe 4-5" long with micro fuses inside. Way up in there, but it's there. Length runs parallel to the length of the chassis if that helps.
  13. Jun 23, 2021 at 1:01 PM
    delphiwiz
    Dave
    Butler, PA
    Sorry VietGuy, been busy.
    I will find some time and post some pictures but as 2mchfun stated, its up there, it's a small box, you do need to remove the plastic cover on the left, take a flashlight and reach up there, it is closer to the firewall and above the hood release cables.
    Dave
