On the fence, 275/60 R20 or 33x12.50 R20
Discussion in 'General Tundra Discussion' started by CavBlueTexan, Dec 11, 2019.
  1. Dec 11, 2019 at 6:42 AM
    CavBlueTexan
    CavBlueTexan [OP] New Member
    Justin
    Tyler Texas
    2019 TRD Sport 4X4 Crew Max
    I am currently running 275/60 R20 on 20x9 +18mm offset wheels. I am wondering how the 33x12.50 would look on the same wheel. 33x12.50 is about the same height but a bit wider. Is anyone running 33x12.50 on a 20x9 +18mm offset wheel that they would be willing to share pics of? Thanks in advance!
  2. Dec 11, 2019 at 6:52 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    It's only 0.85" (22mm) further out on either side. Barely a change at all.
    sundance likes this.
  3. Dec 11, 2019 at 6:53 AM
    CavBlueTexan
    Justin
    Tyler Texas
    Oh ok. I was picturing it to be more
  4. Dec 11, 2019 at 6:55 AM
    Sas
    OKC, OK
    Gotta keep in mind that the change isn't just to one side of the tire, but is split down the middle. So half of the width goes to the inside and the other half goes to the outside.
  5. Dec 11, 2019 at 6:56 AM
    CavBlueTexan
    Justin
    Tyler Texas
    Good point! Thanks for that info.
  6. Dec 11, 2019 at 6:57 AM
    Sas
    OKC, OK
    YW, is a good resource for helping to visualize and plan for tire/wheel changes if you don't already have it bookmarked.
  7. Dec 11, 2019 at 7:00 AM
    CavBlueTexan
    Justin
    Tyler Texas
    Even better, thanks again!
  8. Dec 11, 2019 at 7:06 AM
    CavBlueTexan
    Justin
    Tyler Texas
    Thanks for the visual, that setup looks real nice!
  9. Dec 11, 2019 at 7:38 AM
    Fire123
    Fire123 New Member
    2015 White 1794 Edition
    7" BDS w/ Fox, Fuel Wheels
    Go to www.customwheeloffset.com and put your specifics (wheel set up) in the "gallary" section for some excellent visuals to compare.
  10. Dec 11, 2019 at 7:48 AM
    CavBlueTexan
    Justin
    Tyler Texas
    Will do that.. thanks!
