On board air, whos got it and what's your system?
Discussion in '1st Gen Tundras (2000-2006)' started by wiggilez, May 12, 2022.
  1. May 12, 2022 at 5:11 PM
    wiggilez
    wiggilez [OP] New Member
    2004 access cab 4x4 tundra
    Topper, 1.2-2" lift, older motorola radio
    I'm looking at installing some on board air for my truck, originally I was looking for something like this.
    https://www.amazon.ca/VIAIR-Constan...t=&hvlocphy=1002376&hvtargid=pla-451430389141
    but I was at home depot the other day and saw this.
    https://www.homedepot.ca/product/mi...ompact-quiet-compressor-tool-only-/1001554027
    price wise they are pretty simallar, on board air systems can range in price, but for the most part they cost more or less the same.
    The pros for the permanent system
    • it's that it's mounted under the truck and therefore doesn't take up any space in the cab/bed
    • don't have to worry about carrying/charging batteries cause it uses the truck power system
    Cons
    • wiring it up and running air lines around the truck.
    pros for the milwaukee
    • portable, can be used away from the truck
    • I've already drank the milwaukee coolaid and have some m18 batteries
    cons
    • takes up more space in either my cab or bed.
    • got to keep batteries charged up plus will need some way to charge them on the road.
    any points i've missed?
    Darkness and ATV25 like this.
  2. May 12, 2022 at 5:39 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    On board air would be so convenient. My work truck ( Ram ) has an inverter and I charge my DeWalt batteries off of that. If I used my Tundra for a lot of off-road adventures I would seriously sway twords on board air
  3. May 12, 2022 at 5:47 PM
    wiggilez
    I'm gonna put you down as a built in vote, my four main uses would be tires, inflatable kayak, air mattress and clean/dusting off.
    ATV25[QUOTED] likes this.
  4. May 12, 2022 at 5:48 PM
  5. May 12, 2022 at 6:07 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I vote permanent. My buddy has that VIAIR with the huge tank in his Jeep and it seems to do him well. Only thing thats questionable is where you're going to mount the tank. Not sure if that could be mounted on the frame in the rear without ditching your spare tire.
    You can run a twin ARB without a tank and it'll kick butt inflating tires.
    If you have the skills to make a mount, on top of the ABS accumulator and power steering reservoir is a good place to hard mount stuff.
    I reccomend using Teflon on your fittings and skipping snake clamps for these if you want to not worry about leaks.
    Darkness and Sunnier like this.
  6. May 12, 2022 at 6:22 PM
    wiggilez
    if i do permanent mount I'm looking at mounting it in the frame rail on the passenger side across from the gas tank.
  7. May 12, 2022 at 6:43 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    403B4BD1-02E0-497B-A92E-28A995D62290.jpg Mounted where the spare would generally be. Almost 5 gallons of air.
  8. May 12, 2022 at 6:46 PM
    wiggilez
    I'm still running a spare in the stock location, so this location is a no go for me unfortunately
  9. May 12, 2022 at 6:47 PM
    FrenchToasty
    Mo
    Bone stock
    I’d have to measure, but it’s thin enough, it probably clears the tire.
  10. May 12, 2022 at 7:07 PM
    daveeasa
    David
    I have two ARB twins and neither is installed. I even have an expedition essentials rear cubby mount for it. And a ton of the metripack connectors and terminals.
    All my time goes to crying and yelling. My family is a total war zone.
    Darkness and shifty` like this.
  11. May 12, 2022 at 7:23 PM
    FrenchToasty
    Mo
    Bone stock
    You plan on running dual duals? Color me Impressed
    Darkness likes this.
  12. May 12, 2022 at 7:33 PM
    daveeasa
    David
    One for each truck. Except I kinda have 3 now.
  13. May 12, 2022 at 7:34 PM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
    ARB with plumbed in lines at each tire, air up and down, all 4 tires at the same time, same PSI
    Outbound, Darkness, ATV25 and 4 others like this.
  14. May 12, 2022 at 7:36 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Cue the angry first gen memes…
  15. May 12, 2022 at 7:36 PM
    FrenchToasty
    Mo
    Bone stock
    I’ll be in your neck of the woods at the end of June, hitting Riggs
  16. May 12, 2022 at 7:37 PM
    FrenchToasty
    Mo
    Bone stock
    Creepin from the shadows I see!!!
  17. May 12, 2022 at 7:41 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Always creeping. Busy as hell lately so haven’t been posting as much. Whatcha doing up this way in June? I think I’m a bachelor from the 26th to the first, so I might have to hit up you and/or @AZBoatHauler for some shenanigans.
    Darkness and AZBoatHauler like this.
  18. May 12, 2022 at 7:49 PM
    AZBoatHauler
    So.Arizona
    Isn’t that the week no one in Phoenix can go outside due to it being hotter than actual hell?
    :devil:
  19. May 12, 2022 at 8:27 PM
    BayRunner
    2017 Tundra Platinum
    I run a ARB twin with a tank under the hood and another under the passenger side.
    Darkness, alb1k and bmf4069 like this.
  20. May 12, 2022 at 8:42 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  21. May 12, 2022 at 8:43 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I will tell you, that Milwaukee will suck batteries down faster than me with a mich ultra.
    Mater and Darkness like this.
  22. May 12, 2022 at 10:35 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    If the only con to on board air is wiring and plumbing, there are no cons in my mind.
    If you are considering a 5 gal tank, you can add air tools to the pro column. And air horn. I need one of those.
    [​IMG][​IMG][​IMG][​IMG]
    Mater, Darkness, Sunnier and 2 others like this.
  23. May 12, 2022 at 10:40 PM
    alb1k
    Left Coast
    It's good
    Tank fits over the rear axle
  24. May 13, 2022 at 3:05 AM
    wiggilez
    Not sure if I have the necessary self control for a train horn on my truck :p
    robabeatle, Darkness and bmf4069 like this.
  25. May 13, 2022 at 7:45 AM
    alb1k
    Left Coast
    It's good
    No one does :rofl:
    ATV25, robabeatle and Sunnier like this.
  26. May 13, 2022 at 7:52 AM
    daveeasa
    David
    I’m physically unable to use the horn. Happens when you grow up in Hawaii. My hand simply refuses.
  27. May 13, 2022 at 7:55 AM
    alb1k
    Left Coast
    It's good
    And I learned something new today. Aloha and Mahalo.
    daveeasa[QUOTED] likes this.
  28. May 13, 2022 at 7:58 AM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    what are your intentions with the onboard air? If you are only adding it to air up/down tires, it would be easier to just buy a portable viair. If you want it for tools, airbags, then onboard is the better route.
  29. May 13, 2022 at 8:07 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Running the dual arb compressors under the driver seat. This was originally the arb kit that came in a mobile case that I converted into permanent install.
    robabeatle, des2mtn and alb1k like this.
  30. May 13, 2022 at 8:12 AM
    des2mtn
    Shady Grove
    Tonto cover
    Glad I spent money on that reading course instead of on a new truck :crapstorm:
