OME Springs
Discussion in 'Suspension' started by Nightshade, Jul 23, 2021.
  1. Jul 23, 2021 at 5:59 PM
    Nightshade
    Nightshade [OP] New Member
    Anyone have OME front springs on their 3rd gen? I have a 5.7L engine and confused as to which spring I should order if I plan to keep the truck stock besides the suspension and wheel upgrades. 2612 says stock load but 2613 says 5.7L heavy load. The 2612 or the 2613???
  2. Jul 24, 2021 at 5:58 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    FYI OME suspensions lift a bit higher than advertised. They list 2.5, but expect another 1/4 inch at least. The light duty springs are about 10% stiffer than stock. If you use the heavy duty suspension on an otherwise stock truck, expect about 3 inches lift to 3.5 and a very firm ride.
    Use the light duty springs unless you have a heavy front bumper and winch.
    I have run OME suspension on a few vehicles. They make good stuff, lasts a long time, works well and not too costly. I have the light suspension on a 06 4runner for many 6 years and about 75k miles, the 4runner still rides great and I have never had an issues with any of the suspension.
    There are a few threads of reviews and other stuff about OME here, just use the search feature in upper right to find them.
    Nightshade[OP] likes this.
