OME Shackles?
Discussion in 'Suspension' started by biggsy, Aug 4, 2022.
  1. Aug 4, 2022 at 5:21 AM
    biggsy
    biggsy [OP] New Member
    Warren
    2010 Tundra DC Rock Warrior
    Hello,
    I am replacing my stock leaf springs with a brand new leaf pack from General Springs (stock lift). Since I will be doing that I decided to change the shackles and bushings. For OEM height, it seems the only option are Toyota and OME. I read that the OME does not provide lift but may need to change out the bushings on the leaf spring. Can anyone confirm that? The new leaf springs already came with bushings so if I can avoid changing that, that would be great. I do know that I will have to change the bushings that are in the frame which is what I would like to do anyways. Thanks!
  2. Aug 4, 2022 at 5:30 AM
    The OME's will be quite good. Greasable too. I believe you can order the poly bushings from OME if they don't come with the shackles already.
  3. Aug 4, 2022 at 5:49 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Black Wolf likes this.
  4. Aug 4, 2022 at 6:03 AM
