OME Lift Kit with or without UCA?
Discussion in 'Suspension' started by lawfarm, May 20, 2019.
  1. May 20, 2019 at 1:45 PM
    lawfarm
    lawfarm [OP] New Member
    2018 Tundra SR5 Premium TRD Crewmax
    Planning on the OME 2.5" lift with the 613 springs for my 2018 Tundra Crewmax with a steel winch bumper and winch.
    I talked to Toytec (where I'll get it) and they indicated that new UCAs were not necessary with this lift. That seems counterintuitive based on everything else I've read.
    Anyone have practical experience with this lift kit and their UCAs? I've searched and found conflicting info...
    Black Wolf likes this.
  2. May 20, 2019 at 1:50 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    From what I have read 3"+ is the general cut off for requiring adjustable UCAs
  3. May 20, 2019 at 2:57 PM
    Grumpy Uncle
    Pat
    CO
    I'm running OME and I did the UCAs. Did I need to? Maybe not! I did it anyway.
  4. May 20, 2019 at 3:18 PM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    I have an OME lift and I have the stock UCA's and I have never been told by the alignment specialists that there was a problem aligning the front end.
    Be prepared for a significantly stiffer ride.
  5. May 20, 2019 at 3:24 PM
    I have the OME with the 614. You don't need aftermarket UCAs. I still have my OEM and got a great alignment although I will upgrade to adjustable SPC's. Been putting that off for some time but will be an improvement. In other words you don't need to get aftermarket now. They are easy to swap in when you really think you need them. Yes, ride stiffer on the hwy but damn good off the beaten path.
    BlackSheep and myt1 like this.
  6. May 21, 2019 at 4:26 AM
    lawfarm
  7. May 21, 2019 at 5:06 AM
    Grumpy Uncle
    Pat
    CO
    I have the medium springs, no winch or after market bumper.
