OME Lift and 35's
Discussion in 'Suspension' started by tractorking, Oct 3, 2016.
  1. Oct 3, 2016 at 5:43 PM
    tractorking
    tractorking [OP] New Member
    2007 Black Tundra SR5
    All stock except 285/65r18 Toyo Open Country at ll
    I know this topic has probably been beaten to death but I haven't found anyone with stock wheels with this setup and I want to make sure this will work before I spend all this money. Can I fit 35x12.5R18 Toyo Open Country RT's with an old man emu lift? I want to keep my stock wheels which are +60mm offset I believe. I am also willing to trim fender if needed.
  2. Oct 3, 2016 at 6:01 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I'm not expert, but I haven't heard of anyone on here that's fit true 35's with the 3" OME. Even if you can I have a feeling you're gonna rub quite a bit with the stock rims, unless you use 1.25" spacers.
  3. Oct 3, 2016 at 6:07 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Nope. You'll need wheel spacers with that tire width.
    you'll definitely need a CMC, flap removal and probably trim the skid plate. It'll be tight bro.
    Get a test fit and go from there
  4. Oct 3, 2016 at 6:08 PM
    You CAN run the 35" on stock. I had the Toyos, but needed ET lugs. DT kept playing games, so their DM showed up and offered me any pair of wheels I want absolutely free of cost.
  5. Oct 3, 2016 at 6:12 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Without spacers? On a 60mm offset?
  6. Oct 3, 2016 at 6:15 PM
    tractorking
    Alright Thanks for the quick replies guys. I should be able to fit 285/75R18 with that setup right?
  7. Oct 3, 2016 at 6:24 PM
    Not sure if I had spacers or not. Maybe. :notsure:
