OME coil overs destroying upper ball joints
Discussion in 'Suspension' started by chrisba, Aug 11, 2019.
  1. Aug 11, 2019 at 6:26 AM
    chrisba
    chrisba [OP] New Member
    I put on a set of OME front coil overs approximately two thousand miles ago. About 500 miles ago I replaced the upper and lower ball joints because the boots had split. I new the coil overs would be ruff on the uppers but i figured the boots split because they were already old. Well the new boots have split on the uppers already.
    I am trying to decide whether to put the SPC upper control arms on or go back to stock ride height. I don’t drive this truck often but when I do I need it to be reliable. I don’t want to solve this problem with the upper control arms and then just have another problem arise costing me another $650.
    Any advise would be greatly appreciated. It’s a 2002 tundra 2wd.
  2. Aug 11, 2019 at 7:23 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Gen 1 stock uca’s were more susceptible to this than gen 2. New uca’s will fix it and get your alignment better as well
    Black Wolf likes this.
  3. Aug 11, 2019 at 7:37 AM
    bajaphile
    bajaphile New Member
    Solana Beach, Ca
    2001 4x4 Limited
    Icon Coilovers, Icon AALs, JBA headers, 285/75r16 BFG KO2s
    How much lift are you running? I assume you've had alignments done? Something doesn't seem right to me to be honest. Just speaking from my own experience, I've run lifted applications of almost identical suspensions (3rd gen 4Runner's) on stock UCA's since 2000 and never had a single failure. Many of those years were on OME coils.
    Did you replace with OEM ball joints? Got any pictures of the coilover installed?
    FirstGenVol and Casper421 like this.
  4. Aug 11, 2019 at 8:19 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    So your just having an upper ball joint boot failure?
  5. Aug 11, 2019 at 9:05 AM
    chrisba
    Yes I am only having ball joint boot failure but I would presume the ball joint itself wouldn’t last too much longer once dirt starts getting in there. The OME say they add approximately 2.5” but it seems more like three.
  6. Aug 11, 2019 at 9:06 AM
    chrisba
    They were Moog ball joints.
  7. Aug 11, 2019 at 9:16 AM
    Bif
    Bif New Member
    Bif
    2014-1794 Edition
    Stock
    I haven't lifted Toyotas yet but just from what I have been reading UCA's are the ok
    only way to lift . I cannot advise on which brand or models but there is some great YouTube videos I gotta see if I can find it. These suckers were beautiful!
  8. Aug 11, 2019 at 9:16 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I've never
    That's most likely your problem. Everyone says you have to go OEM on the ball joints. The other ones don't last.
    Watt maker likes this.
  9. Aug 11, 2019 at 10:26 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Something is wrong.
    My guess is you're lifted too high and maxing out the ball joint(s).
    That's really the only reason why they would tear.
    Swap the springs to the next number down.
    I ran 2.5-3" of lift on my 99 Tacoma with stock UCA's and never had an issue with ball joint failure.
  10. Aug 11, 2019 at 10:33 AM
    ou77kg
    ou77kg New Member
    Erik
    2016 Tundra CM Platinum 4x4
    Bilstein 5100’s set to level my 05 DC caused my ball joints to fail three times. SPC’s fixed this and alignment is dead on. Worth the $$$$!
  11. Aug 11, 2019 at 12:21 PM
    chrisba
    This is the upper ball joint when the truck is parked. Looks like it didn’t actually split but rather pulled the boot free. I think I am going to order the SPC UCA’s.
  12. Aug 11, 2019 at 1:18 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Looks like a low quality boot/ ball joint. The angle actually doesn't look bad.
    I prefer OEM only for things like ball joints and tie rods.
  13. Aug 11, 2019 at 4:27 PM
    Bif
    Bif New Member
    Bif
    2014-1794 Edition
    Stock
    Spindle looks too short IMO I think good UCA's be the best solution?
