Ok to remove cab mounted brake light?
Discussion in '3rd Gen Tundras (2022+)' started by KrissyMattAlpha, Mar 14, 2024.
  1. Mar 14, 2024 at 5:21 AM
    KrissyMattAlpha
    KrissyMattAlpha [OP] New Member
    2023 SR5
    I have an ARE Z2 cap on the bed of my truck and I'm going to attempt to shape some neoprene foam as a seal between the cab and the cap. I already have the GG.Offroad camera relocation kit installed to move the cameras to the rear of the cap.
    My question is...Can I remove the cab mounted brake/cargo light and leave those cables unconnected without any issues?
    Reason I am asking is... The light housing is quite obtrusive and I don't think I'll be able to get a good seal with the neoprene foam on such an irregular shape. If I remove the housing, I'm pretty sure I can adequately seal the hole with some 12 or 14 mil paint protection film. Then I plan on using 8 mil ppf on the rest of the cab where the foam will adhere with some 3M VHB.
  2. Mar 14, 2024 at 5:58 AM
    waynescaggs
    waynescaggs No more of that .
    Wayne
    Idaho
    2019 tundra Crewmax Limited
    Be careful when you put the fine in between the cab and the cap it will possibly wear the paint.
