Ok hate me for this..oil filter cap replacement
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sonicbluerider, Sep 9, 2021.
  1. Sep 9, 2021 at 12:01 PM
    Sonicbluerider
    Sonicbluerider [OP] New Member
    Dennis
    2019 Tundra
    Call my toyota folks an gave them this
    Oil Filter Housing Cap Assembly with Oil Plug, Replace 15620-31060, 1562031060, 15643-31050 an they said that this was for smaller engines.. anyone have proper parts # for the 5 .7 gas engine oil cap housing??
  2. Sep 9, 2021 at 12:05 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  3. Sep 9, 2021 at 12:05 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
  4. Sep 9, 2021 at 12:25 PM
    Sonicbluerider
    Dennis
    2019 Tundra
    so I guess my parts guy is off the mark!!! assuming you guys have the 5.7 gas engine!!!
  5. Sep 9, 2021 at 12:26 PM
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
    ZappBrannigan likes this.
  6. Sep 9, 2021 at 12:26 PM
    AZBoatHauler
    So.Arizona
    His computer probably says no because you need to modify it by moving the filter tube over from the old housing. It isn’t a “direct” replacement.
  7. Sep 9, 2021 at 1:07 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Yup. The perforated "spindle" needs to come out of the stock plastic oil filter housing cap and go into your new one. See below.xxeerr.jpg
  8. Sep 9, 2021 at 2:07 PM
    Sonicbluerider
    Dennis
    2019 Tundra
    thanks folks..!!! I'll go face to face an talk with them!! AWESOME
  9. Sep 11, 2021 at 4:04 AM
    Sonicbluerider
    Dennis
    2019 Tundra
    does that tube just pull out or is there more to removing it??
  10. Sep 11, 2021 at 4:08 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    The base, where it connects, just requires that you push it down lightly and twist. Twist lock so to speak. Your new aluminum one will be exactly the same. You'll see it clearly once you look inside there (after you douche everything out with Brake Clean). If you can get that hot chicks bra off, in the dark, when you're drunk, you'll be able to do this NO PROBLEM.
  11. Sep 11, 2021 at 4:14 AM
    Sonicbluerider
    Dennis
    2019 Tundra
  12. Sep 11, 2021 at 5:31 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    Can't believe they give us the plastic crap
  13. Sep 11, 2021 at 6:10 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
  14. Sep 11, 2021 at 6:12 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    chugs, coldcanuk and BTBAKER like this.
  15. Sep 11, 2021 at 6:13 PM
    parkerbows
    Jack
    Me too
  16. Sep 12, 2021 at 4:16 AM
    Tigereye
    Tigereye New Member
    Eric
    2019 SSM Limited
    bed liner, diamondback se, level kit, nitto ridge grapplers,tufskinz letters, grab handle
  17. Sep 12, 2021 at 10:22 AM
    Retroboy1989
    Northern Utah
    On my '12, I reused the metal plug from the plastic housing, it's the same part.
  18. Sep 12, 2021 at 10:47 AM
    Flying Fuzz
    Flying Fuzz New Member
    2019 GX460 Premium with Sport package.
    I bought PN 15620-31060 for my Tundra but traded it in on a Raptor before I could install the metal filter housing. My wife has a 2018 Rav4 Adventure and this fit on her vehicle so it isn’t 5.7L specific.
    Retroboy1989 likes this.
  19. Sep 12, 2021 at 10:57 AM
    Retroboy1989
    Northern Utah
    Tundra is not on this list because that part number technically does not fit.
  20. Sep 12, 2021 at 11:40 AM
    adamreinhardt
    adamreinhardt Blk 17 Platinum 4x4
    Seattle
    2017 Platinum in Midnight Black Metallic
    Hey I have the metal housing and need to swap the inner cylinder. When you say bend tabs I assume it’s those small bits that look like spot welds? I haven’t done it yet because I’m afraid I’ll snap them off. Any tips? Thnx!
  21. Sep 12, 2021 at 11:45 AM
    AZBoatHauler
    So.Arizona
    The tabs are circled in red. It will make sense when it’s in your hands.
  22. Sep 12, 2021 at 1:21 PM
    Flying Fuzz
    Wife’s Rav4 is a 2018 and it fit even though the list you provided doesn’t reflect that Mine came in a Lexus box too.
    bulldog93 likes this.
  23. Sep 12, 2021 at 1:57 PM
    adamreinhardt
    Seattle
    Appreciate the help!
  24. Sep 12, 2021 at 2:26 PM
    Retroboy1989
    Northern Utah
    Evidently toyota has moved to all plastic. So that part number doesn't show your '18, because the "correct" part is not aluminum.
  25. Sep 12, 2021 at 3:18 PM
    Flying Fuzz
    All of those vehicles have the 3.5L V6 option which would explain why the I4 in the Rav4 or V8 Tundra isn’t listed. Weird.
  26. Sep 12, 2021 at 3:30 PM
    swallace
    swallace Insert profound statement —> here <—
    Steven
    Tri-Cities, WA
    2014 Silver Sky Metallic CM 4.6L 4x4
    6112/5160, DD 10”, Amp steps, Alea leather, more…
    What are the consequences of not switching out the inner cylinder? I recently switched my filter cover to the metal one, but didn’t switch the inner cylinders.
  27. Sep 12, 2021 at 5:21 PM
    AZBoatHauler
    So.Arizona
    Filter could collapse on itself and kill your oil pressure. I’d fix it ASAP.
    Internet pic for illustration.
  28. Sep 12, 2021 at 5:47 PM
    Retroboy1989
    Northern Utah
    Well this is terrifying.
    Take a picture when you drop it out. I'm curious to see if it has collapsed.
  29. Sep 12, 2021 at 6:42 PM
    swallace
    Steven
    Tri-Cities, WA
    Whelp…at least now I know.
    Two related questions…
    1. I threw away the old filter cap with the longer inner cylinder. What is the part number for that?
    2. Can I drain and change the oil filter without draining the oil from the pan?
  30. Sep 12, 2021 at 7:07 PM
    Retroboy1989
    Northern Utah
    1. You have to buy a new plastic cap to steal the cylinder. 15620-38010
    2. You can change just the filter. You will need a quart or so to top back off.
    bulldog93 and Black@Blue19 like this.
