Oil
Discussion in 'Performance and Tuning' started by FBH, Mar 21, 2024.
  1. Mar 21, 2024 at 6:31 PM
    FBH
    FBH [OP] New Member
    2023 TRDOFF Limited
    Hi simple question, I personnally run 0w30 amsoil signature series on my Tundra. Would there be any problem with that instead of the 0w20 appart from the fuel consomption? Thanks alot
  2. Mar 21, 2024 at 7:23 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Is there a reason you started using 0w30 in the first place? Seems like if you made the conscious, personal decision to use something other than the factory spec 0w20 then you'd likely have a reason and would have determined if there'd be an issue with that beforehand. :D
    ZappBrannigan and terraj66 like this.
  3. Mar 21, 2024 at 7:54 PM
    FBH
    FBH [OP] New Member
    2023 TRDOFF Limited
    The only reason I tought about the 0W30 is the benefit of the 30 when towing and it’s pretty hot in Summer, since I keep the 0W for the Winter I didn’t tought there will be a problem of using it. The only reason I asked that is, by example the clearance of the engine wouldn’t allow the 0w30 as minimal as it look I was just concern. Thanks
  4. Mar 21, 2024 at 8:09 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Nope. Been running it under the same conditions for 240k miles. Burns zero. Leaks zero. Spotless under valve covers.
    Settle down “the toyota engineers said 0w-xxxx” fans. Im just saying the stuff hes asking about works.:goingcrazy:
    I’ll add…mines a 5.7, just noticed you have the gen 3.
    nobodyintexas and FBH[OP] like this.
  5. Mar 21, 2024 at 8:20 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Fair enough, I'm not saying it doesn't work or causes any issues. Just saying it seems like you'd ask these questions and figure that out before using it. Carry on.
    ZappBrannigan and FBH[OP] like this.
  6. Mar 21, 2024 at 8:22 PM
    FBH
    FBH [OP] New Member
    2023 TRDOFF Limited
    I understand what you mean,I didn’t explain it well in my question, thanks
  7. Mar 21, 2024 at 8:33 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Hooray a new oil thread my favorite!!
    :D:D
  8. Mar 21, 2024 at 8:33 PM
    FBH
    FBH [OP] New Member
    2023 TRDOFF Limited
    Ahahahaha
  9. Mar 21, 2024 at 8:35 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Honestly I figure the engineers know what they are doing, at Toyota anyway, which is why I buy their products, so I try to stick with their recommendations.
  10. Mar 22, 2024 at 7:49 AM
    Tom976
    Tom976 New Member
    Tom
    Larly5000 and FBH[OP] like this.
  11. Mar 22, 2024 at 7:50 AM
    FBH
    FBH [OP] New Member
    2023 TRDOFF Limited
    Really interesting, thanks you
