Oil weights
Discussion in '2.5 Gen Tundras (2014-2021)' started by PNJ 4x4, Dec 5, 2023.
  1. Dec 5, 2023 at 10:58 AM
    PNJ 4x4
    PNJ 4x4 [OP] New Member
    2018 TRD OFF ROAD
    I used 5w-20 Penzoil my last oil change at 65k miles. All previous changes from new were the 0W-20. Is it ok to use the 5w-20 for a Northern NJ winter with trips to Vermont? Or should I go back to the 0w-20 for the winter?
    I'm not to mechanically savvy, hence the reason I'm asking
  2. Dec 5, 2023 at 11:06 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Won't matter at all, run whatever you want.
    Mdl likes this.
  3. Dec 5, 2023 at 11:42 AM
    kirkb
    kirkb Tired New Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    I'll admit to not knowing 100% but personally I wouldn't deviate from whats documented in the owners manual but that's just me.
  4. Dec 5, 2023 at 12:13 PM
    tarathetundra
    tarathetundra New Member
    Nate
    2018 white CM
    37x13.50R18
    I personally don’t know the technical aspect of it either. But I’d be interested to know if you used the penz 0w20 that says it’s compatible for 5w-20 or just the straight 5w20 this has always confused me as if you can run whatever what’s the point of oil spec lol
  5. Dec 5, 2023 at 12:24 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Use the 5W-20 and don't look back. Let that big ole V8 warm up a bit when you head out on a cold morning/day/night.
    I run 5W-30.
    KNABORES and Mdl like this.
  6. Dec 5, 2023 at 12:27 PM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
  7. Dec 5, 2023 at 1:14 PM
    PNJ 4x4
    2018 TRD OFF ROAD
    5w-30? All year round? What year and how many miles on it?
  8. Dec 5, 2023 at 1:19 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    The owners manuals for these motors call for anything from 0w20 all the way up to 15w40 and everything in between. Literally run whatever you want, it won't matter.
    Do some searches on here for how many motors fail due to oiling issues. Let us know what you find.
  9. Dec 5, 2023 at 1:20 PM
    PNJ 4x4
    2018 TRD OFF ROAD
    lol...thx
  10. Dec 5, 2023 at 1:52 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Pennzoil Platinum 5w30. Was starting it at 8 F a week ago. Not a hiccup, no nothing. Don't even see any MPG difference with 0w20.
  11. Dec 5, 2023 at 1:58 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    I'd run 5w30 for the 5.7. Even a 40 for summer.
    CaptRussia253 and KNABORES like this.
  12. Dec 5, 2023 at 2:21 PM
    Retired...finally
    Can we include the Gen 3's?
    PermaFrostTRD likes this.
  13. Dec 5, 2023 at 2:55 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I have feeling especially Gen3 will benefit from thicker oil.
    Mdl likes this.
  14. Dec 5, 2023 at 4:48 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Been running 5w30 year round for 75k miles.
    Mdl likes this.
  15. Dec 5, 2023 at 4:56 PM
    Retired...finally
    Mdl likes this.
  16. Dec 5, 2023 at 5:36 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Very well.
    I know nothing of the weight of a lubricant. I consider API designations from my manufacturer and then consider a grade that best suits my application.
    If I have to start carrying a scale around to measure the mass of engine lubricant then I'm out and going straight to EV... immolation risks be damned.
    Do you hear me, @Eurodriver ?! Done, I says!!
  17. Dec 5, 2023 at 5:38 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Also, any 20 grade oil is piss water. Even 15W/20.
    Leo's first likes this.
  18. Dec 5, 2023 at 5:41 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    +1 for 5w-30. Pennzoil Ultra Platinum.
  19. Dec 5, 2023 at 5:47 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Any of you guys running the Pennzoil Ultra Plat burn any oil?
  20. Dec 5, 2023 at 5:49 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    My oil cap says 0w-20 OR 5w-20
  21. Dec 5, 2023 at 5:50 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    None that I'm aware of, I'm at 32k on my truck. Has there been reports of it burning?
  22. Dec 5, 2023 at 5:58 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    No, but I've only put about 2k miles on it. Truck has a hair over 20k. 5k oil change interval.
    I never burned oil in either Tundra I had, but both were basically new
  23. Dec 5, 2023 at 6:57 PM
    ZPhilip
    Philip
    West Chester, PA
    I’ve been running the PUP in 0w20 and 5w30 and my truck is consuming some oil between changes. I haven’t tried other oils to track other brands consumption.
  24. Dec 6, 2023 at 12:15 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    Seems somewhat common for Toyota's from other posts, forums, and YouTube I've seen. How many miles on your truck?
    I doubt it matters on oil brand. But, who knows.
  25. Dec 6, 2023 at 2:02 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I also add a bottle of stp zddp treatment at oil changes. With our 5.7 vvti chain tensioner issue it can only help.
  26. Dec 6, 2023 at 2:37 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Just remember that all the nut houses and trailer parks have internet too.
    Don't ask for advice about oil on the internet.
    clay5313, JLS in WA, kirkb and 2 others like this.
  27. Dec 6, 2023 at 2:53 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It all depends on what oil your using. Some manufacturers limit the amount of zinc. We dont want too much but having it around 1100ppm helps lubricate. If I ran Rotella brand I wouldn't add zinc since it's about 1200ppm zinc. Just a crazy Redneck idea...
  28. Dec 6, 2023 at 3:03 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Can't afford.
    PermaFrostTRD and Leo's first like this.
  29. Dec 6, 2023 at 3:35 AM
    Bammer
    Monroe, CT
    :bowdown:
    Leo's first and hagrid[QUOTED] like this.
  30. Dec 6, 2023 at 3:36 AM
    Bammer
    Monroe, CT
    Mobil 1 0W30 gets my vote
