Oil usage
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by PNJ 4x4, Aug 1, 2023.
  1. Aug 1, 2023 at 11:19 AM
    PNJ 4x4
    PNJ 4x4 [OP] New Member
    2018 TRD OFF ROAD
    How much oil usage are people seeing between the 10k factory changes? Is a quart normal?
  2. Aug 1, 2023 at 11:30 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
  3. Aug 1, 2023 at 11:31 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    but...my answer
    I use zero oil on 5k changes.
    no God fearing, self respecting, grown-ass man goes 10k between changes.
    sask3m, Leek128, coldcanuk and 7 others like this.
  4. Aug 1, 2023 at 11:40 AM
    PA Trout Sniffer
    PA Trout Sniffer New Member
    21 crew trd off road sr5
    Trans cooler, rear sway
    I’d be alarmed
  5. Aug 1, 2023 at 11:48 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Are you putting in 8.5 quarts when you do an oil change?
  6. Aug 1, 2023 at 11:50 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I'm at 95,000 miles and do the 10k engine oil change intervals and haven't ever used any engine oil.
    Point of reference: my 1997 T100 with V6, 275,000 miles, has never (I've owned it since new) used oil between changes (3,000 miles on dino oil, last two oil changes I've switched to synthetic oil and go 5,000 miles between engine oil changes).
    Bad Cow likes this.
  7. Aug 1, 2023 at 11:58 AM
    Mr Badwrench
    Mr Badwrench New Member
    Is your exhaust tip oily? Doesn't sound "totally normal " but if you don't observe any other issues, you're probably okay. There is an oil consumption allowance somewhere in the owners manual.
    I don't think 1 quart is considered excessive though.
    Not to be an insulting question, but did you check it under similar conditions.. level, engine shut off for 10 minutes etc?
  8. Aug 1, 2023 at 12:01 PM
    PNJ 4x4
    2018 TRD OFF ROAD
    I don't change it myself but have noticed a bit of usage and I don't abuse the truck. I had a 2018 SR5 5.7L that also used a bit of oil before selling at 45k miles. My old 4Runners(V6) didn't use any and I drove those to 200k miles and sold them so I was a bit alarmed by the Tundra V8 usage
  9. Aug 1, 2023 at 12:05 PM
    2mchfun
    I have a pcv catch can on mine and yes some your oil is going into the combustion chamber via the pcv.
    I'd say between a half and 1 quart in 10k would be just a tad over normal. Really depends on how it was broken in, how many miles on it, what oils were used, how you typically drive it, etc. Long story short, change it every 5k and use 5w30.
    Silver17 and AZBoatHauler like this.
  10. Aug 1, 2023 at 12:08 PM
    2mchfun
    I have a catch can on my 4.0 Runner as well, they do blow some oil through the intake too. Not much, but noticeable.
  11. Aug 1, 2023 at 12:08 PM
    PNJ 4x4
    2018 TRD OFF ROAD
    Don't use 0W20 per Toyota?
  12. Aug 1, 2023 at 12:09 PM
    2mchfun
    I don't and won't. That's for gas mileage, not engine life longevity.
  13. Aug 1, 2023 at 1:43 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    I second the nomination ^^^.
  14. Aug 1, 2023 at 2:52 PM
    AZBoatHauler
    So.Arizona
    /thread
  15. Aug 1, 2023 at 3:04 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    If you are having someone else change your oil, i would bet that they arent filling it all the way. 8.5 quarts is alot and i bet they are doing less. The next time they do your oil change, check the level immediately yourself and monitor it.
    How much and style of driving would play a role too.
    nobodyintexas likes this.
  16. Aug 1, 2023 at 3:12 PM
    Figgy
    Figgy New Member
    Rene
    Vancouver, BC
    2018 White CM TRD Off Road
    May I kindly inquire as to what oil spec is best for longevity? :)
    2mchfun[QUOTED] likes this.
  17. Aug 1, 2023 at 3:14 PM
    MadMaxCanon
    now that question is bait lol
  18. Aug 1, 2023 at 3:14 PM
    AZBoatHauler
    So.Arizona
    There are countless factors prohibiting a one size (or viscosity) fits all answer but 20 weight definitely isn’t it.
    2mchfun likes this.
  19. Aug 1, 2023 at 3:19 PM
    Figgy
    Figgy New Member
    Rene
    Vancouver, BC
    I just got curious, is all (innocently..lol) :)
    MadMaxCanon[QUOTED] and 2mchfun like this.
  20. Aug 1, 2023 at 3:26 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Not changing the filter will save you a quart or so
  21. Aug 1, 2023 at 3:27 PM
    2mchfun
    The one that is changed frequently without breaking the bank and is a bit thicker than water.:thumbsup:
    AZBoatHauler and nobodyintexas like this.
  22. Aug 1, 2023 at 3:30 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    my $.02
    all oils are the same, change it regulary and keep it filled
    Engines don’t fail based on viscosity, they fail based on starvation.
    Dealerships use the cheapest bulk shit available and trucks stay running
    here endith the lesson.
    Figgy[QUOTED] likes this.
  23. Aug 1, 2023 at 4:07 PM
    MadMaxCanon
    Oil change places are notorious for not changing filters but that would mean the oil would stay in there. They could save themselves 2 quarts by not changing the filter and shorting a quart on the dipstick. Fuckers.....
    coldcanuk and 2mchfun like this.
  24. Aug 1, 2023 at 5:41 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    The dealer put in 10.5 qt last time in wife's Sequoia... I guess, the mech was new to the jugs the dealer uses, so he thought he works with gallon jugs. But anyways, he is who screwed it up.
  25. Aug 1, 2023 at 5:54 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Dealerships are well informed, properly tooled and only lie on Fridays. + + +
    Self performance requires knowledge, shmancy tools, messy, fraught with risk and offers no recourse. - - -
    There are harder decisions in life.
