Oil pressure numbers, what are you seeing?
Discussion in '3rd Gen Tundras (2022+)' started by mrlittlejohn, Nov 27, 2024.
  1. Nov 27, 2024 at 9:25 PM
    mrlittlejohn
    mrlittlejohn [OP] New Member
    Michael
    2022 Toyota Tundra Limited
    I installed a scanguage 3 in my truck a few days ago. Pretty cool, but more info than I really need... LoL I installed it for future plans to tow my RV and want to monitor transmission fluid temps. I will get an external cooler before summer trips.
    One of the PIDs I'm watching is the oil pressure. Numbers are odd, but I am not freaking out. I believe I saw somewhere here that the system varies the oil pressure for different functions internally. It definitely varies a lot. I an seeing between 15 and 32 PSI few and far in between the middle area.
    I know oil pressure is not what's overall important. It's oil flow. I had built a pretty nasty V6 Buick several years ago (had to sell it, or it was going to kill me). I went to my engine builder with concerns of 5-10 PSI at idle and would increase with RPMs. He explained that oil flow is what is of value. He assured me that everything was perfectly fine and I now feel this way. Oil pressure is just that, pressurized oil that is not aiding anything in that condition.
    Thanks in advance for any inputs,
  2. Nov 27, 2024 at 10:38 PM
    CrayCray
    CrayCray New Member
    WA State
    2024 Platinum 6.5
    I see it jack up to 3/4 on the read-out when the engine is totally cold. Then when the motor heats up to a stable temp, it pretty much stays a little bit below 1/2.
    mrlittlejohn[OP] and FoopaKing like this.
  3. Nov 28, 2024 at 2:39 AM
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    My SG3 reads about 78 psi at cold idle and 15 when warmed up. And everywhere in between while running.
    mrlittlejohn[OP] likes this.
  4. Nov 28, 2024 at 4:29 AM
    FoopaKing
    FoopaKing New Member
    2024 SR5
    This is exactly my experience. 2024 SR5.
