Oil Pressure Gauge
Discussion in '2nd Gen Tundras (2007-2013)' started by Yinzer73, Jun 22, 2023.
  1. Jun 22, 2023 at 8:42 AM
    Yinzer73
    Yinzer73 [OP] New Member
    Menifee, Ca
    2011 Tundra 5.7
    None yet but the list is growing
    I have noticed that the oil pressure gauge increase's considerably while accelerating, but does go to the middle while not accelerating. This may be totally normal for this truck. I have never seen this in other vehicles that I have owned, as it normally stays pretty consistent.
    I have check the oil level and it is spot on. Truck runs and drives perfect.
    I get the idea that while under pressure from acceleration it would make sense that the pressure would go up, just not used to seeing it on the gauge that much.
    Normal operation for the Tundra's?
  2. Jun 22, 2023 at 9:03 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    That appears to be normal.. The last time I freaked out, was when mine dropped to a 1/4 and came back up to the middle once I started moving. I was told that was normal, but I've never seen it done it before.
    Yinzer73[OP] likes this.
  3. Jun 22, 2023 at 9:03 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Normal, and all vehicle's do that though their gauge may not display it (like how coolant temperature gauges often dont move over a wide range of temperature). Engine rpm goes up, oil pump rpm goes up, oil pressure goes up.
  4. Jun 22, 2023 at 9:10 AM
    Yinzer73
    Menifee, Ca
    2011 Tundra 5.7
    I figured as much, but had never seen this or noticed it on other vehicles that I have or have had. I am still feeling this truck out and getting use to the little/major differences between this and others that I have had.
  5. Jun 23, 2023 at 7:27 AM
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    It makes perfect sense. When the engine is revving higher the oil pump spins faster, so oil more oil is being pushed to the various engine parts.
