Oil pressure gauge
Discussion in '2nd Gen Tundras (2007-2013)' started by alexh59275, Apr 21, 2023.
  1. Apr 21, 2023 at 11:08 AM
    alexh59275
    alexh59275 [OP] New Member
    2012 4.6L Tundra 2WD
    I’ve notice that my oil pressure gauge tends to rise up quickly even when I’m at 1500rpm it will sit between middle and H. It will go back to a little below half but tends to rise up quickly when I accelerate. Anyone know if this is normal?
  2. Apr 21, 2023 at 6:07 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    My 4.6 bounces of the pressure regulator when cold and to your point settles when warm but generally floats north of the center line if above 1500 RPM...
    I'd call it normal.
    alexh59275[OP] likes this.
  3. Apr 21, 2023 at 8:11 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    It’s normal to see if fluctuate with the RPM. The cluster uses the oil pressure sender and Rpm value to move the gauge. If you don’t have an Rpm signal the gauge will not move.
    I found this out with my benchtop cluster. As soon as I sent an Rpm signal the oil pressure gauge started working
    Wynnded and KeepOnTruckin like this.
  4. Apr 21, 2023 at 10:20 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Totally normal
  5. Apr 21, 2023 at 10:21 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
  6. Apr 21, 2023 at 10:51 PM
    blenton
    blenton New Member
    Normal. Or, at least mine does the same thing. Oil pressure is a good thing as long as it’s above zero and below pegged.
  7. Apr 22, 2023 at 1:57 PM
    KeepOnTruckin
    Randy
    Interesting tidbit. I wonder why they did that. I didn't notice in your video.
    Thx
