Oil Present In Front of Engine
Discussion in '2nd Gen Tundras (2007-2013)' started by ecs87, Oct 15, 2020.
  1. Oct 15, 2020 at 2:20 PM
    ecs87
    ecs87 [OP] New Member
    Hey There!
    I have a 2011 Toyota Tundra. Over the last week I have noticed that there is an oil type substance in front of the engine right next to the hood latch. I dont see any of this oil in the engine compartment. Any idea what may be causing this?
    Thank you!
  2. Oct 15, 2020 at 2:27 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    Someone peed on your truck yo
    Clear/yellow-ish, could be power steering fluid leaking. Check the cooler lines.
    hagrid likes this.
  3. Oct 15, 2020 at 2:31 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    power steering resi full, steering noises or issues?
    AC working correctly?
  4. Oct 15, 2020 at 2:33 PM
    timsp8
    NY
    That’s a weird spot for fluid, but it looks like there is some splashing on the right plastic piece that directs airflow. Just to the right of the horn in the pic. Check all your fluids and if they are good clean it off and see if it comes back.
  5. Oct 15, 2020 at 2:34 PM
    timsp8
    NY
    Is Freon yellow? The splashing is right by the ac hoses. That could be it.
  6. Oct 15, 2020 at 2:35 PM
    ecs87
    I have wiped it off and it has come back. Fluids look good . Has me puzzled.
  7. Oct 15, 2020 at 3:13 PM
    Medicineman
    Medicineman Not so new member
    Western MD
    2011 MGM Rock Warrior Crewmax
    Heated Leather Seats, Morimoto XB LED and 4-Banger fogs, TRD Pro “style” grille, Bushwhacker Flares, Line-X, Leer Cap, Yak Rack
    Washer fluid leak? What color is your washer fluid? If the hose from reservoir has a leak/ bad connector near the windshield, it could follow the passenger side of fender down to the front top of bumper if parked downhill facing?
    Black Wolf likes this.
  8. Oct 15, 2020 at 3:19 PM
    Why not leave the hood up, start the engine, turn on AC, wriggle the steering wheel, and watch..........
    TheBeast likes this.
  9. Oct 15, 2020 at 4:36 PM
    Hvactech24
    Hvactech24 MGM
    Kentucky
    2013 Rock warrior double cab
    2-1/2” front leveling kit, spider trex wheel spacers, line-x bed liner, change all lights over to led bulbs interior, exterior, and headlights. All bulbs are from headlight revolutions, RCI skid plates. RCI running boards
    Check your A/C. Freon has oil in it. It keeps your compressor lubricated I have done heating and air for 27 years, so if your AC is not working IT could have a small leak. that’s a pretty big one that’s a lot of oil, if it gets low it has a low pressure switch in it, On your compressor of course, it will not let it come on. But all Freon does have a oil in it.
  10. Oct 15, 2020 at 4:54 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I like your thinking ;)
