Oil Pan Leaking
Discussion in '2nd Gen Tundras (2007-2013)' started by dano4003, May 23, 2017.
  1. May 23, 2017 at 1:00 PM
    dano4003
    dano4003 [OP] New Member
    2007 Toyota Tundra
    So... I parked on my street facing up hill. when I moved the truck I found this, see attached picture. the oil pan is leaking from the gasket. it is oil soaked around the edges. Has anyone else had this problem???
  2. May 23, 2017 at 1:01 PM
    millerstone
    millerstone New Member
    2017 TRD Pro DC Cement
    The gasket for your oil drain plug?
  3. May 23, 2017 at 1:05 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    have a look above that seal around the block. What can happen is that an oil leak above that, flows down and then disperses around that horizontal flange making it look like the seal itself is leaking. You'd need to use a mirror to access some places but i'm pretty sure the leak will be somewhere else rather than the seal itself
  4. May 23, 2017 at 1:15 PM
    Could be a oil gasket. Really hard to tell just with a photo of oil on the ground. Have you looked around on the truck?
    TheBeast likes this.
  5. May 23, 2017 at 2:18 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Have not had that problem. Drain the oil, pull the pan down, remove old gasket and install new gasket. Don't over torque or you will bend up the oil pan and mess up the seal.
  6. May 23, 2017 at 2:31 PM
    dano4003
    2007 Toyota Tundra
    i did take in to the dealership and they told me that all the bolts were 1/8 turn loose. the whole pan is wet all around the pan. it seems dry above the oil pan. the dealership told me that it might also be the oil dipstick tune o-ring. I checked that as well, and it is dry also.
    i plan on changing the gasket this weekend, the thing that sucks is that I just changed the oil about 1500 miles ago...
  7. May 23, 2017 at 2:33 PM
    csuviper
    Broomfield, CO
    Use a clean container to catch it and add it back in if you want.
  8. May 23, 2017 at 2:36 PM
    dano4003
    2007 Toyota Tundra
    not sure I trust it... and really not worth the cost of new oil over that of a new motor...
  9. May 24, 2017 at 11:29 PM
    JTP
    JTP The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    How many miles are on this truck? I think that you said 120k in the new member intro.
    Ive never had a oil pan gasket go bad on any of my Toyota's. Even on my 225k miles 1994 Land Cruiser
  10. May 25, 2017 at 5:35 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    It's fipg. Not a gasket....
    landphil and T-Rex266 like this.
  11. May 25, 2017 at 7:07 AM
    csuviper
    Broomfield, CO
    NewImprovedRon likes this.
  12. May 25, 2017 at 5:35 PM
    dano4003
    2007 Toyota Tundra
    It has 126k on it... as soon as it get back out of the shop for the starter that just died, i'm going to change the oil pan gasket and the dipstick tube o-ring.
    ColoradoTJ likes this.
  13. May 25, 2017 at 7:55 PM
    JTP
    The Big Black Moose
    Holy crap dude, Ive never had a starter issue. Are you sure that this truck was not in a flood or something.
    Seals, gaskets, electrical problems on this "low of mileage" Yoda sounds like flood damage.
    Toyota builds vehicles and components like Nikon and Sony build stereos and cameras. Shit never breaks and hardly ever wears out UNLESS YOU GET THEM WET.
    dano4003[QUOTED][OP] likes this.
  14. May 27, 2017 at 8:15 AM
    dano4003
    2007 Toyota Tundra
    It's all true... in less then four months that I have owned this, it has been back at the dealership, now 6 times. so far they have been very great, they have jump started it at my house, towed it from vip parking lot, and took me in with little wait time on my part. this last time, it was towed because it would not start. they hard to cut off the exhaust to get the old starter out and the new one in. they told me that someone had broke some of the header bolts. they even gave me a rental, a chevy spark... those things are cool... 44 mpg compared to the 14 or 15 in the tundra... it's nice to have her back...
