Oil Pan Drain Plug Washer
Discussion in '2nd Gen Tundras (2007-2013)' started by TundraMax12, Nov 26, 2019.
  1. Nov 26, 2019 at 6:32 AM
    TundraMax12
    TundraMax12 [OP] New Member
    Dom
    2013 TSS Crewmax
    Called the dealer to see if they had any oil filters in stock and also inquired about the oil pan drain plug washer. They want almost $2 for the washer!!!
    Anyone know of a good place to either order these or pick them up in bulk for a better price?
  2. Nov 26, 2019 at 6:37 AM
    koditten
    Kirk
    Midland of the Mitten
  3. Nov 26, 2019 at 6:38 AM
    SouthWestGA
    SouthWestGA New Member
    Also search on eBay
    They’re in bulk cheaper
  4. Nov 26, 2019 at 6:53 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  5. Nov 26, 2019 at 8:08 AM
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    I saw an ad on eBay for ten for $10.
  6. Nov 26, 2019 at 8:23 AM
    15whtrd
    15whtrd Mr. Blonde
    When I was doing it conventional style I never changed it and never had a leak. My wife’s car which is an XB 2008, takes the same gasket. I finally had to change hers after 10 years because it had a little drip. Wished I would’ve changed it sooner because it did show signs. But in the middle of a project I didn’t feel like going and getting any. Now I keep some in the garage and if they look bad I’ll change it. But you can typically get a long life out of one washer. Now I have the drain valve on the tundra. No more gasket changes LOL.
    NewImprovedRon likes this.
  7. Nov 26, 2019 at 8:36 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Wow, $2 is a little steep for a washer. My dealer hands me one for free every time I buy a filter and oil.
    Drew281, NewImprovedRon and WILLINH like this.
  8. Nov 26, 2019 at 8:46 AM
    AZBoatHauler
    So.Arizona
    Be warned - I researched the Amazon ones and found several reviews indicating they were counterfeit. When used, they would melt to the oil pan and be a huge PITA to clean off.
    focal likes this.
  9. Nov 26, 2019 at 2:31 PM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    I don't believe there is one on the 5.7l engine, my 2010 does not have one.
  10. Apr 13, 2021 at 3:17 AM
    737fixer
    737fixer New Member
    Your going to have three choices for an oil drain plug washer.
    Choice #1 = No washer at all. This is how my brand new Tundra was shipped and is reported by many as the same. Not good as every manual states to use a washer.
    Choice #2 = Dark almost black washer. This is the washer that all new Toyota's and Lexus vehicles are supposed to have from the factory. Enjoy it cause it will pretty much
    be the last time you see it.
    Choice #3 = Blue Washer. Part # 90430-12031. This is the absolute standard for every Toyota and Lexus vehicle for the last 20+ years. Its what every dealer carries and should
    be included free with every filter. If your dealer charges you $1-$2 bucks for this you need to question everything they do.
  11. Apr 13, 2021 at 3:44 AM
    brobert225
    brobert225 Firm grasp of the obvious
    20 yrs worth of oil changes and still using the original washer. I am not sure how you damage it actually. I would not trust aftermarket washers.
    snivilous likes this.
  12. Apr 13, 2021 at 5:54 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    And then there's an oil drain plug VALVE. Such as Fumoto. Truly "one and done."
  13. Apr 13, 2021 at 10:39 AM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    My oem black one finally cracked on me causing a drip recently. I was glad to see it was only the washer and not a bigger leak/problem
    Just get a $2 one from Toyota and call it done. Should last at least another decade
  14. Apr 14, 2021 at 1:46 PM
    idiggplants
    idiggplants New Member
    PA
    2013 DC 4wd
    5100 fronts middle setting 5100 rears 3rd gen offroad wheels softopper ditch lights
    I have literally never replaced a washer in the 30 years I've changed oil on any of my vehicles, quads, bikes, generators, mowers, etc. Never took notice to one being there or not being there. Never a leak or drip, etc.
    Psv and snivilous like this.
  15. Apr 15, 2021 at 9:34 AM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    I've even forgotten to put one on and did not loose enough oil to be noticeable between oil changes.
    Just made the pan a little wet.
