Oil on single spark plug
Discussion in '2nd Gen Tundras (2007-2013)' started by Jandrews319, Feb 26, 2024.
  1. Feb 26, 2024 at 6:38 PM
    Jandrews319
    Jandrews319 [OP] New Member
    Derrick
    2010 Toyota Sequoia Limited
    I was changing my spark plugs on my 2010 Sequioa and the second from the front on the passenger side (either 4 or 6, not sure which) was coated in fresh oil. All of the other plugs were dry and seem to have burned normally. From what I've read, I unfortunately believe this to be either the valve stem seals or the piston rings. Is there anything else that could cause this or would you agree with my diagnosis?
  2. Mar 4, 2024 at 10:15 AM
    Tundrasam97
    Tundrasam97 New Member
    Sam
    Qc, Canada
    2010 black tundra SR5 DCSB 3ur-fe
    Bilstein 5100
    Oil is on the combustion side or on the white porcelain?
  3. Mar 4, 2024 at 10:22 AM
    Jandrews319
    Derrick
    On the combustion side. I also had oil in the air intake behind the MAF so I replaced the PCV valve. I'm going to check the plug that had oil on it in a week to see if anything has changed.
  4. Mar 4, 2024 at 10:28 AM
    Tundrasam97
    Sam
    Qc, Canada
    Bilstein 5100
    If you have oil in the intake it is comming from your pcv system for sure. Have you notticed oil comsuption and blue smoke?
  5. Mar 4, 2024 at 10:30 AM
    Jandrews319
    Derrick
    No noticeable smoke but it's definitely consuming oil at a slow rate. Normally about a quarter or so between oil changes.
  6. Mar 4, 2024 at 10:32 AM
    Tundrasam97
    Sam
    Qc, Canada
    Bilstein 5100
    Update us with your result next week! Hope the pcv valve was your issue
  7. Mar 4, 2024 at 10:57 AM
    AZBoatHauler
    So.Arizona
    See here.
    https://forum.ih8mud.com/threads/oil-on-spark-plug-threads.1327761/
