Oil of Choice... Synthetic or Natural?
Discussion in 'General Tundra Discussion' started by 03Yoda4x, Apr 2, 2015.
  1. Apr 2, 2015 at 5:35 PM
    03Yoda4x
    03Yoda4x [OP] New Member
    Dave
    Battlefield, MO
    2007 Tundra SR5 Quad 4x
    3" front and 1" rear lift, and a bunch of little things
    My truck is getting ready to hit 150,000. The previous owner sucked at maintenance. The skid plate was held on buy a ratchet strap and one bolt. What oil should I use?
  2. Apr 2, 2015 at 6:01 PM
    cadis10
    cadis10 New Member
    2011 CREWMAX TRD
    TRD exhaust, 3" lift 33" and 22's
    I run full synthetic in my tundra and it has 80000 on the clock.
    03Yoda4x[OP] likes this.
  3. Apr 2, 2015 at 6:31 PM
    Synthetic. Mobile1.
  4. Apr 2, 2015 at 8:15 PM
    Mike Tread lightly.
    south carolina
    Synthetic mobil 1 only... you can use the high mileage oil if you want... just remember to use toyota oil filters only for the check valves. That helps reduce no oil pressure on start up...
  5. Apr 3, 2015 at 7:34 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    X2
  6. Apr 3, 2015 at 7:43 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Synthetic Mobil1 here too.
  7. Apr 3, 2015 at 5:15 PM
    03Yoda4x
    Dave
    Battlefield, MO
    Thanks! Got it, now just gotta get it done...
  8. Apr 3, 2015 at 7:45 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    I run shaffers 9000 full synthetic and wix filters. Are the toyota ones better?
  9. Apr 3, 2015 at 8:09 PM
    Mike Tread lightly.
    south carolina
    Oem you will notice your valves dont chatter( as miles gets high) when cold and you will notice a faster response time in oil pressure on start up(cold or warm) to do the check valve in place holding oil in the filter.
  10. Apr 4, 2015 at 1:25 PM
    tibadoe
    tibadoe New Member
    Joe
    Gladys
    2014 SR5 DC 4x4
    Synthetic M1
  11. Apr 4, 2015 at 2:04 PM
    robie56
    robie56 New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    Full synthetic Valvoline, with a Toyota filter
  12. Apr 5, 2015 at 9:31 PM
    Rkcruza
    Rkcruza New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    Another vote for Mobile 1!
  13. Apr 5, 2015 at 10:28 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Amsoil full synthetic/ Trd filter
  14. Apr 6, 2015 at 5:30 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Mobil 1 full synthetic with Toyota OEM filter. Though I may pick up some TRD filters!
    T-Rex266 likes this.
  15. Apr 6, 2015 at 5:58 PM
    03Yoda4x
    Dave
    Battlefield, MO
    May have to give the TRD filter a try... next time.
  16. Apr 6, 2015 at 6:20 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Anyone here use Royal Purple?
  17. Apr 6, 2015 at 6:29 PM
    Virgils12
    Is there any difference in the trd and normal Toyota filters?
  18. Apr 6, 2015 at 6:32 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Good question. Besides the logo and price haha
  19. Apr 6, 2015 at 6:33 PM
    George14
    George14 New Member
    West Virginia
    2014 Tundra SR5 Dc TRD Off Road 5.7L with tow package
    None
    Synthetic
  20. Apr 7, 2015 at 6:38 AM
    Used too, but I read a few things about them (forgot what / where exactly) so I made the switch.
  21. Apr 7, 2015 at 9:10 AM
    chphilo
    Western PA
    Are you talking about the TRD air filter?
  22. Apr 7, 2015 at 10:48 AM
    Virgils12
    No the oil filters.
  23. Apr 7, 2015 at 10:57 AM
    Mike Tread lightly.
    south carolina
    Alot had to do with the engine using more oil with rp than others say mobil 1 Also some engines not just toyota but other have seen major engine wear using royal some have seen high failure rate to do the oil. Dont get me wrong Royal is good but, they havn't been though what mobil oil has done when it comes to R&D.
    T-Rex266[QUOTED] likes this.
  24. Apr 7, 2015 at 11:02 AM
    Mike Tread lightly.
    south carolina
    TRD filter uses a different filter and its a less flowing filter ( means it flows more freely) vs the toyota filter.. They would really be ideal in cold weather like 10 degrees and colder climates..
    edit
    http://www.tunemytoyota.com/forum/showthread.php?t=7343
    Example of one torn down..
    robie56 and MotoTundra[QUOTED] like this.
  25. Apr 7, 2015 at 11:21 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Thanks for the info!
  26. Apr 7, 2015 at 1:18 PM
    dandailey
    Dan D
    Newport News Va.
    Thanks for the info. I guess it's going to be M1 then. Don't Tundra's come with synthetic to begin with?
    I have free oil changes for life from the dealer, so not sure what they will want to use.
    jfrd30 likes this.
  27. Apr 7, 2015 at 2:13 PM
    Mike Tread lightly.
    south carolina
    If you have a new engine and you run synthetic the engine will not break in correctly, it takes longer for them to break in then in the manual says. Synthetic just doesn't protect engine parts. what it does it (digs) itself in the metal and forms a bond to the metal. What the oil can do is like tempers the metal to go higher temps. ranges.
    Funny thing is when you convert a dino engine over to synthetic the engine runs cooler. To do a correct way everyone thinks just dump the oil in and it will protect WRONG. When a engine has been in dino you have to do a mixture to it. Reason is simple so the metal can absorb the synthetic oil. Oil changes stay at 3000 miles or 3 months.. start with 60/ 40 then 40/60 then 20/80 then full synthetic. When you reach full synthetic go 3000 miles change it. Now we have a engine that has taken the oil correctly.
    Now remember synthetic oil was made for jet engines. Guess what they dont change the oil in them they only top it off till rebuilds. Ask any A&P tech they will tell you not till rebuild. Even rebuild techs cant find anything wrong with bearings do to how synthetic oil has changed. . Jet engine will see more stress than your truck will see in 500,000 miles... When do you change the oil in your truck? Synthetic is not like dino oil. It doesnt really break down like dino oil does. It properties are different why you dont see dino oil in turbine engines.. Remember synthetic is done is a lab where dino is mother nature so you have some varies there. When do you change synthetic? i get a kick out of this... first thing everyone says is 5000 miles. Really? thats for dino not synthetic. The only way you know when it time to change the oil is when it gets DIRTY. When the color starts to change from lite brown to dark change it. Miles and time are not a factor with synthetic.
    I wish i would have keep a pic i will see if i can find it. my tacoma i had to do valve cover gaskets. While the covers where off i did my inspection, they haven't been off in 6 years i believe. Synthetic oil changed at 15,000 inter, 12,000 inter, and guess what people NO traces of oil sludge anywhere not even in the corners on the engine where oil is not really present. Cams lobes are chrome no marks from oil problems. WTB my tacoma has 270,000 miles on her. Its been a true synthetic since 15,000 miles to convert and shows what Mobil has done.
    Soon either bob or sean is going to banned me from my long posts i do and limit me. :D
  28. Apr 7, 2015 at 4:43 PM
    ^^^ @csuviper might, but we won't ;)
    Your posts are valuable and informational, so please keep posting!
    jfrd30 likes this.
  29. Apr 10, 2015 at 10:07 PM
    csuviper
    Broomfield, CO
    I'm not going to ban. I agree with Sean. You know your Sh!t.
  30. Apr 12, 2015 at 9:00 AM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    2011 Spruce Tundra TRD SR5 2WD
    3" Leveling Kit 3.5" Spindle Lift 4" Rear Blocks AirAid Intake 20" XD Monsters w/ Nitto Grapplers 1" wheel spacers for rear Magnaflow Exhaust Pro Comp Shocks for rear
    i use royal purple as of late, ive used mobil1. i havent noticed any difference. i change mine every 3k either way using full synthetic.
