Oil Maintenance light
Discussion in '2nd Gen Tundras (2007-2013)' started by MKKnuds, May 27, 2021.
  1. May 27, 2021 at 2:48 PM
    MKKnuds
    MKKnuds [OP] God, Truck, Guns, Beer
    Matthias
    Arvada, CO
    2012 Silver Tundra
    Tonneau cover, PlastiDip emblems
    All right, I've looked everywhere trying to find how to clear this light that came on my dash. Oil has been changed and I cannot clear it with my OBD scanner.
    Anything I can do to get it gone and not take it to a dealership?
  2. May 27, 2021 at 2:55 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Push and Hold down trip meter button,turn key on and wait until it stops flashing.
    : I think, it's been a while since I've done it
    MKKnuds[OP] likes this.
  3. May 27, 2021 at 3:00 PM
    MKKnuds
    Matthias
    Arvada, CO
    2012 Silver Tundra
    I will give it a try when I get home. Thank you!
    Dr Doobie[QUOTED] likes this.
  4. May 27, 2021 at 3:10 PM
    Put it on Trip A and then shut the truck off. Push and hold the button, turn the ignition on (you don't have to start it). You will see dashes flash on the display and then each one will disappear one at a time. After the last one and it displays Trip A, you will be good to go.
    https://youtu.be/zAF9Wlz9F8Y
  5. May 27, 2021 at 5:11 PM
    Notarobot
    Notarobot Jagged lines!
    2013 CM
    Tundra234 is correct.
    I like to reset tripA after so I can track miles.
  6. May 27, 2021 at 6:48 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    I work at a mechanic shop...
    Select Trip A
    Turn the truck off
    Hold down the Odometer Reset Stalk
    Cycle truck on to accesory
    You should get something like this: ------ (flashing and counting down)
    then it should change to 000000
    Done!
    If that doesn't work, repeat everything but hold down on just the odometer (some toyotas have the reset light tied to the main ODO and not Trip A, I believe all the Tundras are Trip A tho)
