Oil Leaks on the Left and Right Side of the Block
Discussion in '3rd Gen Tundras (2022+)' started by 7Toys4Me, Dec 19, 2023.
  1. Dec 19, 2023 at 3:24 PM
    7Toys4Me
    7Toys4Me [OP] New Member
    2023 Tundra CrewMax 1794 HV 4X4
    First, my dealer and I have issues going back to 2007 with oil leaks covered under warranty that takes them 4 years to find. It’s a long story, but….
    My 2023 iMax is leaking oil on both sides of the block. This is the third oil change I’ve had done, the first was done by a great local foreign car mechanic and the last two done by my dealer.
    First oil change was done with about 1,100 miles on it, we were leaving on a long trip to the beach and I wanted to get the factory oil out of it. Im an old guy and my experience goes back to the ‘70s.
    When we returned after 5 weeks of beach driving and 6,500 miles on it I had the dealer change the oil at my 5k checkup. They managed to screw that up and I had to take it back.
    I took it in a month ago for the recall and they went ahead and did the 10k service. I was fine with that, it was only a few hundred miles early.
    Now my truck leaks oil on both sides of the block. Bigger spots on the right, about 4” in diameter and drips about 2” in diameter on the left.
    This is my first 4x4 truck and first turbo. Thoughts on where the leak might be from please.
  2. Dec 19, 2023 at 3:28 PM
    Hella Krusty
    Hella Krusty New Member
    I am going with engine? LOL
    Tom976 and hagrid like this.
  3. Dec 19, 2023 at 3:55 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    I would check oil make sure it does not look like a milkshake color. I know you know what I mean. @7Toys4Me
  4. Dec 19, 2023 at 5:56 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Take it back, let them figure it out
    Hella Krusty and Breathing Borla like this.
  5. Dec 19, 2023 at 6:05 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Got any pics?
  6. Dec 19, 2023 at 6:24 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    They probably did what I did and spilled oil on the skid plate. Then there was a bit of residual oil dripping of the skid plate for a short time.
    There isn’t too much else that they could have done to make it leak.
    Mattedfred and Eurodriver like this.
  7. Dec 19, 2023 at 7:48 PM
    OLV1071571
    OLV1071571 New Member
    2024 Silver Limited CrewMax 5.5ft
    Potentially overfilled and the higher oil pressure is causing it to leak maybe? Have your pressure gauges been reading normal?
  8. Dec 19, 2023 at 8:01 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Definitely weird that its leaking on both sides after the oil change. Pics would be helpful if you can.
    raylo likes this.
  9. Dec 19, 2023 at 9:32 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Have read of only one reported leaking valve cover so far. Could be both? My bet is spilled oil dripping down onto the skid plate and spreading
    pwpblue and BoulderGT3 like this.
