Oil leaking from main bell housing AGAIN!
Discussion in '2.5 Gen Tundras (2014-2021)' started by MatthewPTguy, Jun 30, 2016.
  1. Jun 30, 2016 at 9:45 AM
    MatthewPTguy
    MatthewPTguy [OP] Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Hi everyone... Newbie to the forum. I have a 2014 Tundra I bought new in January 2014. In July of 2014 I noticed a slow oil leak from the main bell housing of the transmission where it meets the engine block. The dealership "fixed" it under warranty. At that time the truck had 3200 miles. Fast forward to today... Notice it is leaking AGAIN!! Truck now has 21000 miles. Has anyone else had this problem? Their fix lasted 2 years. What happens when my truck is outside the 6 year 60 k mile warranty? Any ideas? The truck is at the dealership right now and I'm waiting to hear their assessment. I'm going to call Toyota after I hear what they have to say... Ugh... Leaks usually don't get better... Only worse...
  2. Jun 30, 2016 at 9:51 AM
    Mike Tread lightly.
    south carolina
    It should still be under warranty for now... I find it odd it's leaking again..
    Tierhog and FirstGenTundra like this.
  3. Jun 30, 2016 at 10:10 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Not a normal issue. What did they find to be the problem last time? Bad gasket?
  4. Jun 30, 2016 at 10:11 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    No, Toyotas are usually pretty tight. Had my 2000 Tundra for over 10 years and put over 130k miles on her and never a leak. Sorry to hear about your troubles. I know crap like this is frustrating. Maybe take it to another yota dealer. Should still be under warranty even though it shouldn't have happened a second time.
  5. Jun 30, 2016 at 10:36 AM
    I've heard of this before...hopefully a TSB will come out at some point for those that need it.
  6. Jun 30, 2016 at 10:52 AM
    MatthewPTguy
    Eugene, Oregon
    Yes, they said they " resealed the bell housing and block ant reassembled with a new rear crank seal" So it's dripping from the same area... Waiting to hear the tech's assessment today.
  7. Jun 30, 2016 at 11:06 AM
    Make them redo under warranty. Doesn't look too good when they have to fix the same warranty issue twice. They have a good incentive to make sure it gets done correctly. My 07 is as dry as a bone. Not one leak anywhere. Knock on wood.
    TheBeast, kenomouth64 and driverdog like this.
  8. Jun 30, 2016 at 11:20 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    We've seen a few do this. The dowelder pins that hold the rear main seal retainer were not hammered in all the way from the factory. When they reseal the retainer they should tap the dowels in further. I bet there might be a tsb shortly...
    TTund16, equin, Law323 and 5 others like this.
  9. Jun 30, 2016 at 12:23 PM
    MotoTundra
    MotoTundra The Ocho
    Don
  10. Jun 30, 2016 at 3:08 PM
    MatthewPTguy
    Eugene, Oregon
    I just got back from the dealer. They are going to contact Toyota and open some kind of claim or something... PAS or some such thing. They said then Toyota would most likely contact the regional hot shot mechanic and they would advise on what to do. I'm more optimistic this will be fixed right this time
    Black Wolf likes this.
  11. Jun 30, 2016 at 5:47 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Tas. Technical assistance service. But yes that's what we did when we found out the dowel pin thing
    MotoTundra likes this.
  12. Jul 1, 2016 at 5:54 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Look at what they gave you after the warranty work last time. Normally you get 'Life of Ownership Repair Warranty' on repaired items from the dealership.
  13. Jul 1, 2016 at 5:56 AM
    That's good info. I wonder though if that is unique to your dealership?
  14. Jul 1, 2016 at 6:26 AM
    Nor7
    Hmm, yeah does have my dealership's name on it but I'd be surprised if your dealership didn't do something similar.
  15. Jul 1, 2016 at 9:16 AM
    MatthewPTguy
    Eugene, Oregon
    YEAH! That's it! I really appreciate all the information and support from everyone. It really helps to ease my mind and gives me hope that this will have a good outcome. THANKS!!!
  16. Jul 27, 2016 at 9:27 PM
    MatthewPTguy
    Eugene, Oregon
    Hi... Just wanted to give an update on the bell housing oil leak on my 2014 Tundra with 20,000 miles (the second leak... first was at 3200 miles). My dealership had my truck for about a week... They were waiting to hear from Toyota on how to proceed. Just as Lotsoftoys said above... They checked the alignment pin length... Factory spec is 5.2 mm, mine were 7.51 mm. They feel this was the problem all along. They tapped mine in to spec and re-assembled with new plate (I was told but now I can't find it on the parts list of my receipt...) and refilled fluids. GOT MY BABY BACK!!! I called Toyota on 7/25/16... A nice rep listened to my concerns... longevity of fix, what happens if it leaks again AFTER powertrain warranty is up, affect on re-sale value, etc... He was going to talk to his boss, the dealership that did the repair and get back to me.... So the Jury is still out on what they will do for me, if anything... You can bet your a$$ I'm crawling under my truck every month from now on... Better be bone dry under there... Hope this helps anyone else suffering the same problem.
    Trailbreaker, equin, Law323 and 2 others like this.
  17. Jul 27, 2016 at 9:32 PM
    csuviper
    Broomfield, CO
    Thanks for following up on this here. Glad it got fixed and hope it is a permanent fix.
    Y0TA PR0 likes this.
  18. Jul 28, 2016 at 6:09 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Glad you got your baby back, baby back, baby back, baby back ribs!!! (Got carried away there) hope it stays that way brother!! Welcome from South La, by the way!
    RLHULK likes this.
  19. Jul 28, 2016 at 8:01 AM
    Any thoughts of it being defects from the assembly line someone not doing job right???
  20. Jul 28, 2016 at 1:57 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    like i said before, i figured thats what was causing it. really stupid too because all it takes is a tap of the hammer on the dowel pins to the right depth and your in business... im betting a machine installed the dowels....
    equin likes this.
  21. Aug 16, 2016 at 9:01 PM
    MatthewPTguy
    Eugene, Oregon
    Hi everyone... Another update... I contacted Toyota, and a very nice customer service rep named Jay listened patiently to my concerns. He got back to me a few days later, stated Toyota wanted to have happy, loyal customers and offered me a 7 year 100,000 mile Platinum warranty. I said thanks and I would get back to him. I looked up the warranty online... It looks VERY comprehensive. I called Toyota back and asked for the 8 year 125,000 mile Platinum warranty ( you'll never know if you don't ask, right? ). The best they would do is the 7 year. I believe someone earlier in this thread was given the same warranty for a different issue. I feel like Toyota did right by me. I'm a happy and satisfied Toyota customer.
    True confessions... I love my Tundra more than a grown man should...
    kparrow, GODZILLA, roots and 7 others like this.
  22. Nov 27, 2017 at 9:30 AM
    Krabage
    Krabage New Member
    2014 DC TRD
    OP any issues since? I have the same problem on my 14' with only 36k miles, thanks.
  23. Nov 27, 2017 at 1:15 PM
    MatthewPTguy
    Eugene, Oregon
    I don't have the truck anymore... I purchased a 2017... same model etc... love the 38 gallon fuel tank. Fingers crossed on this one
    Krabage, Darth Tundra and ColoradoTJ like this.
  24. Nov 27, 2017 at 1:38 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    OP,
    When you bought your truck new didn't the dealer give you a lifetime powertrain warranty? All the dealers around here do it, the warranty I have is from Zurich with no deductible and is good for life as ling as I own the truck. I read the fine print and it is actually pretty good, covers the whole drivetrain to include all the gaskets and seals.......for free.
  25. Nov 27, 2017 at 3:32 PM
    Krabage
    Krabage New Member
    2014 DC TRD
    Good call, I'm considering going up to an 18' only because of resale but I can't depend on it anymore though.
  26. Nov 27, 2017 at 5:12 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I have a 2018, my first Tundra and I absolutely love it. Very refined, solid and with all the recent changes up to par with any other 1/2 ton out there. And to boot I get the reliability that comes with Toyota, I guess that is one of the reasons the dealers in Missouri give you a lifetime powertrain warranty for free. Most people will not need it.
  27. Nov 28, 2017 at 6:26 AM
    Krabage
    Krabage New Member
    2014 DC TRD
    I felt the same way until this weekend and found this
  28. Nov 28, 2017 at 1:13 PM
    MatthewPTguy
    Eugene, Oregon
    Same thing as my 2014....
  29. Nov 28, 2017 at 4:33 PM
    Krabage
    Krabage New Member
    2014 DC TRD
    Took it in today and they're ordering the parts to start Monday, need it for a week. Did you tow with yours?
  30. Nov 28, 2017 at 4:38 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Sorry to see that bud. I checked mine today nothing. Knock on wood. Hope they fix it right for you.
