Oil leaking after jump
Discussion in 'General Tundra Discussion' started by Tundrahelp, Jul 18, 2021.
  1. Jul 18, 2021 at 12:12 PM
    Tundrahelp
    Tundrahelp [OP] New Member
    5100s front
    First post, jumped my 2009 crewmax on 5100s and now my oil is leaking. Anything I should know? In terms of locating and fixing the problem. I would also like to mention that I just got an oil change which may also be the reason for the leak, but I would like to be sure just in case jumping is the cause.
  2. Jul 18, 2021 at 12:16 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Not too smart !
    rcjh0891 and Black@Blue19 like this.
  3. Jul 18, 2021 at 12:18 PM
    AZTundra
    Paul
    Phoenix, AZ
    Hard to just guess where your leak is coming from. Need more info or some pictures to help diagnose.
    Black@Blue19 likes this.
  4. Jul 18, 2021 at 12:21 PM
    GatorBodine
    GatorBodine New Member
    "Jump" as in went airborne??
    I'd start with checking drain plug tightness and oil filter tightness since the oil was just changed. And check for spills or residual oil laying somewhere from the change.
  5. Jul 18, 2021 at 12:22 PM
    Tundrahelp
    5100s front
    Yes airborne. I know not wise. I will check drain plug and oil filter shortly
    GODZILLA and Leo's first like this.
  6. Jul 18, 2021 at 12:22 PM
    GatorBodine
    Damn brother
    oddhours likes this.
  7. Jul 18, 2021 at 12:25 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Where is the leak
  8. Jul 18, 2021 at 12:25 PM
    Welcome from NY.
    Why would you jump your Tundra?
    Kgfit85 and ColoradoTJ like this.
  9. Jul 18, 2021 at 12:27 PM
    Outbound
    Aaron
    Northern Alberta
    Please tell me you have video of the jump.
    I'd check the oil pan and drain plug first.
  10. Jul 18, 2021 at 12:27 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Even the raptor can’t handle a jump bruh
    Darkness likes this.
  11. Jul 18, 2021 at 12:27 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Is your battery dead?
    Bikeric, 15whtrd and 2mchfun like this.
  12. Jul 18, 2021 at 12:29 PM
    MaxPower
    MaxPower New Member
    18 Tundra TRD Off road
    I would inspect the oil pan for punctures. I know that Canguro Racings 200 Series Land Cruiser has had this issue as the motor mounts have enough flex in them that the oil pan hits other components and breaks. Different vehicle but same 5.7 engine.
    jerryallday, 2mchfun and ColoradoTJ like this.
  13. Jul 18, 2021 at 12:33 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Just fucking crawl under it and look, how would anyone be able to diagnose what's wrong with your description :rofl:
  14. Jul 18, 2021 at 12:34 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    :burnrubber::bikewhoops: Sweet
    :worthless:
    Branden and TXRailRoadBandit73 like this.
  15. Jul 18, 2021 at 12:35 PM
    Roborob70
    Robert
    Well what do you expect....He's already playing Ivan Stewart!
    Ericsopa and snivilous[QUOTED] like this.
  16. Jul 18, 2021 at 12:36 PM
    Dammit man. I’ve told you before and I will say it again. DON’T BRING LOGICAL THOUGHT PROCESS INTO THESE TYPE OF THREADS!!!
  17. Jul 18, 2021 at 12:36 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Lol. Well alright then. Jumping a stock truck on shocks that are barely designed for any real off roading. Not smart. Maybe get under and look? You probably smashed your oil pan. Need to fix it ASAP or your sump may not pick up and you’ll have a whole other set of serious problems.
  18. Jul 18, 2021 at 12:36 PM
    2mchfun
    As in front wheels off the ground more than a few inches? That's how you break mounts, battery cells, crack radiator, etc. You're lucky the airbags didn't deploy and cause you to crash the whole truck.
  19. Jul 18, 2021 at 12:38 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    RainMan_PNW, Kgfit85, Joro43 and 5 others like this.
  20. Jul 18, 2021 at 12:38 PM
    Could be the shocks blown out. Wouldn’t be the first time on 5100’s
    Hightide, T-Rex266 and 15whtrd like this.
  21. Jul 18, 2021 at 12:38 PM
    RainMan_PNW and Saltyhero13 like this.
  22. Jul 18, 2021 at 12:39 PM
    Roborob70
    Robert
    Oh yes, Good Ole country boys.....Lol
  23. Jul 18, 2021 at 12:47 PM
    2mchfun
    If you are okay with jumping it, why would you be concerned about a little oil leak??
  24. Jul 18, 2021 at 1:00 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    These trucks are amazingly tough. I've seen them (heavily modified) repeatedly catch 3-4 feet of air w/o issue......But modified, we're not talking 5100s either. So the oil leak is interesting. My guess, loose plug or filter. Also gonna guess that you've bent the coil buckets. They're a weak link in the front suspension. Your camber will tell all.
    joonbug, des2mtn, TG705 and 1 other person like this.
  25. Jul 18, 2021 at 1:01 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    What does your crew chief say?
  26. Jul 18, 2021 at 1:11 PM
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    X2
    Outbound[QUOTED] likes this.
  27. Jul 18, 2021 at 1:12 PM
    2mchfun
    Probably something like "now let's get you to the ER so I can get my boot out of your ass!"
    Saltyhero13 and Booney like this.
  28. Jul 18, 2021 at 1:21 PM
    Tundrahelp
    5100s front
    Oil plug and on are both perfectly fine.
  29. Jul 18, 2021 at 1:27 PM
    15whtrd
    15whtrd Mr. Blonde
    Find the wet spot. Maybe you’ll have to throw some flower on it.
  30. Jul 18, 2021 at 1:28 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Only wet spots are on his pants and seat
