Oil leak
Discussion in '2nd Gen Tundras (2007-2013)' started by 86toy2011, Mar 22, 2019.
  1. Mar 22, 2019 at 3:29 PM
    86toy2011
    86toy2011 [OP] New Member
    Alright, this is the second time I'm replacing the alternator due to this oil leak, anyone have any idea where this might be coming from? Replacing alternators is miserable on these trucks.
  2. Mar 22, 2019 at 4:08 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Can use dye to determine where the leak is from.
    Watt maker likes this.
  3. Mar 22, 2019 at 4:17 PM
    15whtrd
    15whtrd Mr. Blonde
    Hard to tell without cleaning everything up and then seeing where it comes from. Or if you have a dye test done. What’s to say it’s not power steering? It could be as simple as a clogged PCV valve causing blow by.
    JohnLakeman and Black Wolf like this.
  4. Mar 22, 2019 at 8:17 PM
    86toy2011
    Last time I replaced the alternator I didnt have time to really diagnose it, I'll clean it up and see if I can tell where it's coming from. I hope it isnt the cam tower leak.
    15whtrd[QUOTED] likes this.
  5. Mar 23, 2019 at 4:58 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Might try following that tube in the upper foreground higher...looks like you have a big fat drop of oil on it, and it's on the way down.
    Hopefully, the tube is not contacting the alternator. Hard to tell from the pic...probably not touching unless it's been "deformed". Vibration would eventually cause the alternator to chew a hole in the tube.
  6. Mar 23, 2019 at 8:13 AM
    86toy2011
    Went put and looked it this morning, that is actually the bottom of a bracket that looks like an oil drop.
    JohnLakeman[QUOTED] likes this.
  7. Mar 23, 2019 at 11:00 AM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    Use Brake cleaner to clean off that gunk, thoroughly . Do that, then start looking for new oil gunk build up.
    TheBeast and 15whtrd like this.
