Oil leak
Discussion in '2nd Gen Tundras (2007-2013)' started by Kirby7887, Sep 29, 2022.
  1. Sep 29, 2022 at 12:54 PM
    Kirby7887
    Kirby7887 [OP] New Member
    Kirby
    2012 Toyota Tundra Rock Warrior
    I have a 2012 Toyota tundra rock warrior 5.7.recently I just did the oil change and saw a little buildup of oil just above the AC compressor. (See pictures). I have done some research and this could possibly be the valve cover gasket, which would be a possibility for the location. I just would like to know if this would be a serious problem or something I can wait, or just leave. I haven’t noticed any oil consumption or loss between oil changes, so this might not be a problem. The first picture shows a front view just above the AC compressor and the second picture shows a view from the front left wheel well. Any information would be greatly appreciated. About 95000 miles and gets oil changes every 5000. TIA
  2. Sep 29, 2022 at 1:55 PM
    Cam tower leak?
  3. Sep 29, 2022 at 2:01 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Yep, from the 2nd picture it looks like you likely have yourself a cam tower leak. My 2018 got it on the driver's side at ~8,000 miles. If you aren't losing a noticeable amount of oil between changes and aren't noticing it on the ground I'd just leave it alone. Long story short, they messed something up on my 2018 when they did the repair under warranty and ended up buying the truck back, so I'd just leave it alone if you're out of warranty.
    Malinois38 likes this.
  4. Sep 29, 2022 at 2:31 PM
    Kirby7887
    Kirby
    Do you think there would be anything to do to it to reduce the risk of it getting worse in the future?
  5. Sep 29, 2022 at 2:34 PM
    AZBoatHauler
    So.Arizona
    As suggested, Other than tearing it apart to fix the failing FIPG, make sure it’s not running low on oil.
  6. Sep 29, 2022 at 4:47 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    I don't really think there is anything to do. Nothing you can add from the outside is going to hold up, and it's really not that big of a deal unless you're losing tons of oil. From what it seems, these don't tend to get a whole lot worse, so I wouldn't worry too much. Just keep an eye on it every oil change :thumbsup:
  7. Sep 29, 2022 at 5:13 PM
    Kirby7887
    Kirby
    Thanks for the insight. It seems like mine is very small seepage super super slow, and loses no oil between changes. So hopefully it stays like this.
    BuckWallace[QUOTED] likes this.
  8. Oct 1, 2022 at 2:28 PM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    I also have a similar leak in that area. One of these days I might try to re-torque the bolts if I can get a socket on them.
