Oil leak after every oil change
Discussion in '2nd Gen Tundras (2007-2013)' started by cgrantp, Feb 5, 2021.
  1. Feb 5, 2021 at 5:12 PM
    cgrantp
    cgrantp [OP] New Member
    2013 red rock warrior
    I upgraded from a Tacoma to a 2013 Toyota Tundra a couple of years ago. Ive noticed that After every oil change I have had done (Toyota dealer, local mechanic, chain place) it leaks oil and I have to bring it back in for them to fix it. Is there a reason that this happens every single time the oil is changed no matter who does it? I’m getting pretty frustrated with this.
  2. Feb 5, 2021 at 5:16 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Do they remove the skid plate when changing the filter? I bet they don't and they just let the oil drain on it. Mine was a greasy mess when I removed it.
    Failure2comply and JimboSlice413 like this.
  3. Feb 7, 2021 at 7:43 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    drain plug is probably not tightened all the way.. When I purchased my 2zz I noticed a small pool of oil dripping while sitting in storage from somewhere... went crazy looking for the leak, cleaned all of it, until I figured it out, the drain plug was slightly loose and dripping slowly...
  4. Feb 7, 2021 at 7:51 AM
    Wallygator
    Stop letting the dealer change your oil. Problem solved.
    All kidding aside, I agree with @bleach , they are not pulling the skid.
    blackdemon_tt likes this.
  5. Feb 7, 2021 at 8:06 AM
    blackdemon_tt
    @Wallygator couldn't agree more.... main reason I stopped taking mine in looong ago.. besides the hefty price and the 3 hour wait
    Wallygator likes this.
